Old 07-12-2012, 05:51 PM   #1
Spark Plug number
The dealer quoted $500 to replace 6 spark plugs. The cost of spark plugs are $30 each and the rest is labor. I may just do the job myself. Can anyone tell me what spark plug I need? Nothing fancy. Just a good OEM replacements.
I have a 2007 Boxster S w/3.4L engine. Thanks.
By the way, I have searched this site, but most folks here have 2001 and older cars, 986 models, and 2.5/2.7 engines. Couldn't find any recommendations based on my model and year car.
Soetekouw is offline   Reply With Quote
Old 07-12-2012, 05:58 PM   #2
bar10dah's Avatar
$30 each? Tell you what, I'll sell you them for $20 each. It's a great deal! Promise!
Hell, for half what the dealer is charging you, I'll drive up to TN and even change them out for you.
Porsche Cayman - Ignition Tune Up - Page 1
bar10dah is offline   Reply With Quote
Old 07-13-2012, 04:38 PM   #3
Thanks for the link bar10dah.
Old 07-13-2012, 05:23 PM   #4
tonycarreon's Avatar
OEM is 10.50 from pelican. it's certainly a DIY. put the car in the air and remove the wheels to make it easier. i did it myself a few years ago.
Pelican Parts - Product Information: 999-170-223-90-M14
Old 07-14-2012, 08:33 PM   #5
Super easy DIY in 1 hr.
Old 07-14-2012, 08:53 PM   #6
Theoretical propagandist
Eric G's Avatar
$4.50/ea from Speed Geek if you are really looking for a bargain.
Old 07-15-2012, 01:14 PM   #7
It's a simple DIY, just did it. He's trying to make about 600+/hour labor on you as it should take someone with a lift and the right tools MAYBE 40 minutes at the very most... as said prior about an hour doing it yourself. That is simple robbery
Leeper is offline   Reply With Quote
Old 07-15-2012, 02:48 PM   #8
Current Cars
I have a 2001 and access to a lift how do I go about changing them and what should they be gapped at ? Thanks
Neekk1 is offline   Reply With Quote
Old 07-15-2012, 04:32 PM   #9
write-up from 101 projects
Pelican Technical Article: Replacing Boxster Spark Plugs and Coils - 986 / 987
pedro also has a really good write up (this is the one i used)
http://www.pedrosgarage.com/Site_3/Change_Spark_Plugs_%26_Tubes.html
stateofidleness also did a write up on the forum here
http://986forum.com/forums/diy-project-guides/26099-another-spark-plug-diy-dummies.html
essentially:
1. put the car in the air
2. remove the back wheel(s)
3. using an allen bit, remove the 2 bolts on the coil packs, remove the coil packs
4. remove the spark plug
5. install new plug (30 Nm, no anti-seize (according to some))
6. replace coil pack (10 Nm on the bolts)
repeat for each plug (there are obviously 6)
they should come "pre-gapped" no need to adjust. if you drop one (like i did) the proper gap is (i believe) .028
