Old 05-13-2012, 06:44 PM   #1
Bumper Fire???? Exhaust Tips
My new performance exhaust system touches the rear bumper. The tips are held up against the bumper pretty strong and it gets pretty hot since it is a high flow muffler.
Do I need to worry?
Is the gray part over the muffler tips made of aluminum or is that plastic. I cannot tell by feeling it or looking at it.
I have seen pictures of other cars whose bumpers caught on fire from exhaust.
Keep in mind that I will be driving it hard at the race track for 4 hours on Saturday. 1 hour breaks after each hour of driving.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 05-13-2012, 06:48 PM   #2
It should not be touching and the muffler does move/twist under acceleration so you should fix it ASAP...
Old 05-13-2012, 06:57 PM   #3
Moderator
I believe what you are referring to is the heat shield. It is made out of metal, aluminum I would guess, as plastic would melt under those high temperatures.
Old 05-13-2012, 07:43 PM   #4
DFW02S's Avatar
Drill out the holes where the muffler hangs on the holder bolts. The muffler will drop off that touch point.
Ask me how I know.
DFW02S is offline   Reply With Quote
Old 05-13-2012, 08:40 PM   #5
Ask me how I know.
The reason for it happening is that the OEM U-pipes do not connect very well with the Top Speed Catback Exhaust and Test Pipes.
I had to really bend the muffler and test pipes to make them go in the U-Pipe.
That bending resisting force is pushing the muffler tips up against the bumper.
I tried making the 2 upper holes on the exhaust bracket larger using a dremel so I can pull the entire exhaust down a few mm. But I still have the problem.
My next solution is to actually get longer top bolts and a bunch of washers(to use as spacers) to let the entire muffler stick out more so there is no strong bending force from the U-pipe pushing it up against the bumper.
@Kenny Boxster
The Heat shield is behind the bumper. I am talking about the gray trim over the muffler tips that you can see from standing behind your Boxster.
00 2.7 5SPD MT
Old 05-13-2012, 08:56 PM   #6
DFW02S's Avatar
The material TS uses is high quality so it isn't an easy grind to elongate the holes, but it worked for me. Mine is 1/2" below the bumper now. Loosen all the bolts so that it hangs as free as possible before tightening it.
For the months (9? 10? not certain) that my tip was actually touching the shroud on top, I just laid a piece of HVAC metal tape against the shroud. It's really only an exhaust cover touching the bumper shroud, not the exhaust tip itself.
Old 05-14-2012, 05:29 AM   #7
Yeah it did take me about 30 minutes to elongate the hole with a dremel.
I will work on it again today trying my other possible solutions to see what works.
00 2.7 5SPD MT
Old 05-14-2012, 05:45 AM   #8
jacabean's Avatar
you can also try shimming out the muffler bracket with some washers , which will push it down . you can also use the shims to balance out fitment for centering the out let pipes. i used some 3/8" thick brass bushings to get good fitment.
Old 05-14-2012, 05:50 AM   #9
jacabean's Avatar
i think the problem is that the test pipes are a little bit on the long side. so shim or cut is your option. i like the look of the pipes sticking out a little more than the stock ones.
Old 05-14-2012, 11:09 AM   #10
That is what I am doing. I have about 20 thin washers that my work was recycling. I am going to use them as spacers and let the entire system move back further, which will make the tips stick out the bumper maybe another inch but thats okay. I just have to find longer bolts from homedepot or lowes.
I will let you know how it goes. I also put together a DIY video with new exhaust sound. I will post that in the DIY thread soon.
What I love about this exhaust is that it feels stock. No rattling. No drone. Sounds stock at idle and under 2500rpm so I won't wake everyone when leaving the house late nights. And then it turns into a GT3-like loud sound when you floor it. It is especially amazing in tunnels and under highway bridges.
00 2.7 5SPD MT
Old 05-14-2012, 06:46 PM   #11
The Combination of Washers and Dremel worked perfectly for both angle and height.
DIY video coming soon!
00 2.7 5SPD MT
Old 05-14-2012, 07:45 PM   #12
DFW02S's Avatar
Nicely done!
Now flush your brakes before the DE!
