Old 01-13-2012, 02:40 PM   #1
Freakin' out... Tranny/Engine Mount?
Gents,
just got my top replaced!! so I'm all excited, and then I hear sounds that aren't normal and sound expensive. I first attributed the different sound of the car running to the new top (with glass), but it seems like the transmission "whine" in 1st and 2nd are more "low" pitch.. kinda like when you leave the vacuum in one spot for too long.
*This is a '00 base Tiptronic*
Car runs fine otherwise, but around 2000rpm (1800-2200 only, nowhere else) there is this "stutter" feel to the car if I accelerate slowly. It feels the same as when your transmission is slipping, but this is more of a noticeable vibration type feel.
The scary part happened today though when I got home. I pulled in to a spot, stopped, and then reversed to straighten out a bit. When I got done reversing, I put it back in Drive and it made this horrid noise like the engine banging against the firewall or something... fearing the worst, I thought to myself, "well... there it goes...". I immediately put it in Park, then back to Drive (almost assuming it wouldn't go into gear for some reason), but it went into gear just fine and I was able to park it.
I've been wanting to replace the engine mount for some time now as preventative maintenance (74k miles with no record of replacement), so I'm thinking it's either the mount is bad or something worse... the tran$mi$$ion. Could it be a misfire or something else even?
stateofidleness is offline   Reply With Quote
Old 01-13-2012, 02:50 PM   #2
tonycarreon's Avatar
sounds almost exactly like what i experienced 2 years ago @ 75k miles.
was driving down the highway and noticed a weird noise. seemed to only occur when i slowed down to right around 2k. it also felt as if my car was slightly shuddering...
i was in dallas at the time. parked at a hotel and when i went to reverse, heard a horrid "BANG/CLUNK" noise. turned it off, checked it out. nothing loose or dangling.
i didn't have any problems driving it to the shop (~15 miles). took a few hours for them to replace the engine mount.
drove it back to maryland and haven't had any issues from it (2 yrs / 20k miles.)
the mount itself was slightly cracked and the rubber material was quite deteriorated. surprised i didn't notice it before it got to that point but i guess it just reached a specific point before it became "really" noticeable.
'01 base + tip. total cost to replace at the shop was $314.
Originally Posted by tonycarreon View Post
was driving back to the hotel this afternoon and all of a sudden, i hear this rumbling sound. i slowed down and it seemed to get a little worse. i sped up and it seemed to go away. after pulling off the interstate, it came back when i slowed down.
back at the hotel i park and everything seems fine. i push the accelerator and it felt like my seat started vibrating. anyway, between 1200 - 2000 RPM there's quite the vibration ( sitting still, not driving ). i'm thinking engine mount. under 1200 / just idling no noise / vibration. over 2000, just fine.
i like dallas, but i was planning to start my drive back home tomorrow.
01' Base Tip w/ 75k miles.
Old 01-13-2012, 03:01 PM   #3
97 Boxster's Avatar
I am ready to order the part and replace mine in the next few weeks. Sounds like its a good idea. I get this shudder at 69-72mph and I have tried everything else and this is my next shot at getting that resolved. Hope it helps and if it doesnt I am certain it will shift smoother.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 01-13-2012, 03:31 PM   #4
Registered Boxster abuser
healthservices's Avatar
may as well do the two lower hoses...
Old 01-13-2012, 05:39 PM   #5
Consider replacing the waterpump, if it has significant miles on it, like 75k, while you are replacing the mount. To get at the mount its much easier if the main coolant hoses are disconnected (which you have to do if you replace the pump) and once the motor mount is out, replacing the pump is an absolute piece of cake. Easy to clean the mating surface on the block and torque all the pump bolts with a torque wrench.
When you replace the mount, be sure to torque the studs that go into the frame to the proper torque. If they are loose, you will strip the threads in the frame when you tighten the nuts on the studs and you will be in a world of ********************.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-13-2012, 06:48 PM   #6
Track rat
Topless's Avatar
At 75K miles- Motor mount, water pump, hoses, L&N T Stat, serpentine belt, inspect the idler pulleys, while you are in there...
Old 01-13-2012, 07:41 PM   #7
what are the hoses exactly? and what does the lower tstat actually do?
Old 01-13-2012, 10:19 PM   #8
Track rat
Topless's Avatar
Coolant hoses. They are 11yrs old and you will have to torque on them pretty good to get them off and replace the water pump. Adding fresh hoses is a no-brainer. The T Stat is right there in the same spot, also 11 yrs old, and the original one is set too high (180F) and of crappy design. The LN 160F T-stat is a much more robust design and will allow your car to run cooler which saves fuel, protects your oil temps and engine, and gives you a little better cooling efficiency with more water flow.
While you are in there and the car is up in the air, coolant drained, might as well take care of a few parts on the common Boxster hit list. You will be glad you did.
Old 01-13-2012, 10:51 PM   #9
well i pulled the trigger on a lift couple days ago so i guess the timing is right? lol
does all the coolant get drained (if that's easier), or just some of it? is it safe to say that my transmission is fine, and it is most likely the engine mount?
i always thought the engine mounts failed slowly, but today it seemed like it was BAM!, all of a sudden. any damage in driving with it like that for a week or two until i get all the parts in?
Old 01-14-2012, 03:08 AM   #10
while not definitive, i'm sure the transmission is fine. i can show you the "spot" my engine mount went out in dallas (just past buckner blvd. on 35) though that's not true - that's just where i noticed it...
Old 01-14-2012, 10:29 AM   #11
Track rat
Topless's Avatar
Get either a Bentley manual or Pelican 101projects and they will walk you through the process. With 75k I would use fresh Porsche coolant also and follow the refill and air purge instructions carefully so you don't run your motor dry and kill it dead. None of this work is terribly difficult but a Porsche is a little odd if you are used to working on Japanese and American cars. This will be a test of how well you follow instructions. Have fun with it.
Old 01-14-2012, 11:32 PM   #12
Fellas,
Is this the correct part number for the cayman mount?
Porsche Boxster Cayman Engine Mount + Bracket GENUINE | eBay
98737502305
I've seen some that end in 4, so want to make sure before ordering.
Thanks!
Old 01-15-2012, 06:17 AM   #13
that looks right - looks like mine.
pelican's site lists the part number as "987-375-023-05-M100" for 1997-2004 the "04" must be the previous revision.
Old 01-15-2012, 11:36 AM   #14
Pelican promotions going on?
edited. wrong thread.
Old 08-27-2012, 04:31 PM   #15
Just an update on this... my transmission was shot. '00 base Tip with 74k miles on it. what a f**king nightmare ordeal the whole thing has been, not to mention expensive. Could've bought another used Box for the price of the transmission replacement.
7 months later (no joke), a used 98 Blazer purchase to get me to work, and a $7,600 repair bill, I'm back on the road.
If only I knew back then what I know now... CPO! CPO! CPO! Extended Warranty! and get a Manual! You can't even buy parts for the Tip tranny... it's pretty much pull and replace...
what an ordeal...
and as if that weren't enough.. I still get the 1128/1130 CEL daily just to put salt in the wound... good times.
There's no substitute.
Old 08-27-2012, 04:48 PM   #16
How often do you change the tranny fluids? Usually autos last forever unless it's been abused...
Old 08-27-2012, 05:20 PM   #17
Theoretical propagandist
Eric G's Avatar
Personally I will change fluid every 40K to 50K miles simply because new fluid is far cheaper then a blown tranny.
Old 08-27-2012, 05:52 PM   #18
I hate thinking this but......did the "top guy" take your car for a ride and ground out the trans ? Or, miss a gear at the wrong time ? Strange things happen when you leave your car. There seems to be no respect for other's property now days. Getting away with it is now the "cool".....DUDE !!! Always take an odometer reading with an understanding that you will not accept this bull shi#.
milliemax is offline   Reply With Quote
Old 08-27-2012, 06:26 PM   #19
How do you miss a gear with a slush box...?
Old 08-27-2012, 06:43 PM   #20
Odometer is always checked as well as placement of all dings/scratches before taking my car to ANYONE.
This is my daily driver so it was never "abused" (not sure how you abuse a Tip really). Car was purchased at 42k miles and fluid was supposedly changed by Porsche dealership I bought it from at that time.
I don't know what it was called, but there was a bearing inside the transmission that broke and was spinning freely, as well as a leaking "double lip seal" that was causing the differential to leak.
