Old 12-26-2011, 08:10 AM   #1
Key Remote Problems
Hey everyone so i drive a 1998 Boxster and i have just one key with the two buttons, the doors won't lock or unlock, the led light doesn't turn on when pressing either button. I replaced the battery and still nothing so opened it again to try another battery just to make sure it wasn't a faulty one and look what fell out.
Can i resolder it or i need a new module from the dealer? how much does this go for?
Speedy164 is offline   Reply With Quote
Old 12-26-2011, 08:36 AM   #2
DenverSteve's Avatar
I couldn't solder it, I don't know about you. They cost a couple of hundred dollars.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 12-26-2011, 11:10 PM   #3
Spinnaker's Avatar
At this point, you don't have anythng to lose if you try to resolder it. It might even work if you're lucky. You will need a soldering iron with a very fine tip, and a magnifier to see what you are doing. I fixed a credit card size calculator once, it wasn't fun because everything was so small. You might even cheat the dealer out of the $350 they want for a new key with programing.
Old 12-26-2011, 11:53 PM   #4
Spinnaker is right, if it were me I'd give it a try. Radio Shack sells an inexpensive fine tipped soldering iron that I have used on small boards (along with reading glasses) with luck:
15-Watt Soldering Iron with Grounded Tip - RadioShack.com
Old 12-27-2011, 03:12 PM   #5
Thanks a lot guys i might as well give it a try now, there's a radio shack two blocks away, thanks for the link making my way there now wish me luck .
Old 12-27-2011, 03:19 PM   #6
Porsche "Purist"
Paul's Avatar
Sometimes you can talk a Shack guy into doing it for you.....
1987 924S. 2002 996TT. PST-2
Old 12-27-2011, 03:27 PM   #7
@Paul good idea i will try that since i actually know two guys there
