Old 07-17-2005, 05:42 PM   #1
Clutch/fluid need warm up?
Hello all,
Probably a dumb question, but I'll ask anyways.....I notice that when first operating my clutch after the car has sat overnight, the first 5-10 shifts seem a little tougher.....No problem getting into gear, but the shifts are not as smooth as after driving after 5 minutes, then smooth sailing after that....Probably normal I'm guessing, but thought I'd ask the resident experts anyways.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 07-17-2005, 06:29 PM   #2
Transmission fluid does not NEED to be warmed up for proper operation but yes, a cold tranny with cold fluid will be a little more balky to shift.
eslai is offline   Reply With Quote
Old 07-17-2005, 06:53 PM   #3
Kind of what I was expecting, I hadn't driven many manual shift cars in a while before buying, and wanted to make sure.....Thanks for the confirmation eslai! Much appreciated
Old 07-17-2005, 10:38 PM   #4
On the 987 and many other cars, on startup of a cold-manual, the car runs at fast idle (about 1200 rpms) for about 90 seconds then goes down. It's been my experience in the past that these vehicles run better (less balky) if you wait till the revs die to normal (sub 1k). Just my .02 cents.
06 987S- Sold
05 987 5-speed - Sold
06 MB SLK350- Lease escapee
SD987 is offline   Reply With Quote
Old 07-18-2005, 08:06 AM   #5
deliriousga's Avatar
All hydraulic clutches are like that. You notice it more as the clutch pad wears.
It's strange because the owner's manual says not to let the Boxster sit at idle, rather drive it immediately. If you do that, the clutch is stiff. If you let it warm up, cat fire risk. That, and it's all backward from what your dad said to do when you were a kid. I'd been warming my cars up for 10 minutes like dad said for years until we got the Boxster and I read the manual. Then I read the manuals to all of the other cars and I was doing everything wrong!
1966 Wife White/Brown Top
Old 07-18-2005, 02:36 PM   #6
Oh wow, I never thought about extra fuel lighting off the cat like that.. hmm...
