03-14-2012, 10:36 AM
#21
Originally Posted by unavita
Wayne, thank you lowering your price and offering free shipping. Is the free shipping still being offered? When I go to place my order, the Pelican website asks me for a zip code and is charging me $14 for ground and $35.50 for 3-day shipping.
Do I need a coupon code or did your prior free shipping offer expire?
Thanks,
~Seppe:dance:
I just ordered mine last week and I had to pay shipping...
01-05-2017, 06:41 PM
#22
Originally Posted by Wayne at Pelican Parts
Some Porsche dealers have been very competitive on price lately, trying to win market share. This has happened at various times over the past 13 years, and typically lasts until the dealership realizes that it can't sell stuff for that cheap and eventually raises it's prices (or goes under). In this case (just guessing), Suncoast would have to order the part, get it in, and then ship it out several days later. Pelican has 36 available to ship right now. In addition, I think Suncoast charges a 15% handling fee + shipping costs on top of that ($32 shipping when I checked out their site). With the purchase of a tank from Pelican, you get free shipping, and this tank would also qualify for free 3-day shipping anywhere in the continental US.
We're constantly reviewing our pricing on various lines. In this case, I did some more research and discovered that our current supplier for this part is way overpriced! So, I have lowered the price on this part down to $250. Not as low as the other guys, but now in the ballpark. You can order the part here: Pelican Parts - Product Information: 996-106-147-08-OEM
Thanks for pointing this out to us,
Wayne
I know this is over 5 years old but now it is $372
01-05-2017, 06:49 PM
#23
07 Carrera S Cab
$320 on Suncoast. Prob even less at Sunset Porsche.
Suncoast Porsche Parts & Accessories Coolant Reservoir
01-05-2017, 06:55 PM
#24
1999 base
01-05-2017, 06:56 PM
#25
07 Carrera S Cab
I stand corrected. They used to beat out Suncoast prices, but maybe that was a while ago...
01-05-2017, 07:06 PM
#26
If the reason for replacement is a leaking Bleeder Valve , it is usually because of failed "O" rings(2) .These can be replaced for pennies. There is a post elsewhere on this.Part of the diagnosis is to wrap each component of the Coolant tank in cling film to see where the condensation occurs.That pinpoints the problem(s).
If the tank has cracked ,I have no better suggestion than a new one from Pelican.
01-05-2017, 07:18 PM
#27
They have just gone up that much
I shopped around and Pelican is within 10% of everyone selling OEM Porsche tanks....and for what looks to be a knuckle buster of a job why use aftermarket. I don't mind aftermarket on some things....but when it comes to cooling your engine....use the best
PS my coolant cap is blue and I have had my car just over 3 years....which is the newest cap ???
01-05-2017, 08:30 PM
#28
Porsche "Purist"
Sunset:
996-106-447-04 Reservoir Cap $21.80
996-106-147-08 Reservoir $298.74
1987 924S. 2002 996TT. PST-2
01-05-2017, 08:33 PM
#29
Porsche "Purist"
Deleted duplicate
Reason: Deleted duplicate
01-06-2017, 05:05 AM
#30
Multi-Boxer Driver
Parts prices often make no sense.
For example, the trunk/frunk/engine bay (some models) light assembly is $8.75 from Pelican (OE), which is fairly reasonable. Compare that to the glovebox light, which is the same exact part except the bulb holder inside is made for a smaller festoon bulb.
$198.50
Yes, you read that correctly.  That's about the same as what others are charging as for some reason the price exploded in the last year (I recall it being around $20 before). I mean it is a 928 part versus a 996/7 for the trunk light... I replaced the glovebox light in my 911 with the trunk assembly, fits perfect.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
01-06-2017, 08:43 AM
#31
Administrator
Genuine parts prices fluctuate and change over time, as you can see this pricing was posted about 4-5 years ago.
Here are other options: Pelican Parts - Coolant Expansion Tank
For reliability on the brands other than Genuine, I did a search in our system to back in 2014 and 2015. 996-106-147-08-Y-INT has no returns due to failure. It does come with a 12 Month / 12,000 Miles warranty as well. It is ordered from us often.
01-06-2017, 07:28 PM
#32
When I do this I will use a Genuine Porsche, I have a question one you have listed as German is even more expensive than a Genuine Porsche ???
01-09-2017, 09:06 AM
#33
Administrator
The one listed as German is $220, which is over $100 cheaper than the Genuine Porsche part price listed.
01-09-2017, 09:47 AM
#34
Plug in this part number to Fleabay and you can find one for $50 !
About a year ago I did that. What a fiasco . There were many faults with the tank and it may have caused catastrophic overheating. For example :- the tank is assembled from several different mouldings. These are bonded together.There are a variety of orifices that connect the various chambers. Unfortunately these holes did not align .Some were effectively blocked One other just leaked.
If I had not examined the tank very carefully before fitting it ,the consequences could have been expensive.
My point is this - the cost of the tank is a trivial issue. The question is the difference in price between tanks that work correctly. That difference is small.
The other point is the labor in R&R of the tank.It is a horrid job because of limited access to the hose connections on the other side of the firewall.
If you go to all the trouble and expense of fitting a defective tank and then having to return it and replace with a good one, you will waste a lot of time - at best. You will certainly get a trunk full of coolant and if you overheat the engine....it will be a very expensive mistake.
The other expense to factor in is the cost of a Mayhew plier set for the impossible-to-reach connections, an Airlift to burp it and lots of fresh coolant.
You did check the water pump for leaks/weeps didn't you ?
At least if you buy from Pelican, the parts are good, they are decent about any problems and they are fast. The Fleabay guys, not so much.
I still have the old defective tank that I use for Show-and-Tell. Pelican should have a Show-and-Tell type response to these Threads. Dickering about part costs is fun but it is only a (small) part of the story. Pelican (and Forum members) would benefit from reading the rest of the story. It would make for a great YouTube video !
01-09-2017, 07:08 PM
#35
Wonder why no one ever marketed a comparably priced tank in aluminum. The tank is easy to remove but a PIA to install, Would be nice to know you didn't have to do it again.
01-09-2017, 07:37 PM
#36
Pelican
you have one listed as a German Part
Part #: 996-106-147-07-INT
$435 and no image or info....this is the one I was talking about
01-10-2017, 12:01 AM
#37
Perfectionist
Pelican has really good customer service. They have my support.
01-10-2017, 08:07 AM
#38
Administrator
That is a Genuine part from a different supplier. It is not searchable through the catalog and pops up when you put in the part number for the tank (also has a different part number, ends in 07 instead of 08). We may not have as good as pricing from that supplier on that Genuine part. The part that comes straight from the dealer, with the associated dealer warranty, is 996-106-147-08-M100. That is the one you'll want to purchase.
01-10-2017, 06:50 PM
#39
Many Thanks Luccia
Dwight
01-10-2017, 08:16 PM
#40
The big mistake was locating the hose clamps high and tight up against the rear bulkhead. If the hose connections/clamps were in the trunk it would have been easy to change.
There are so many jobs on the Boxster where Porsche severely compromised access for the mechanic to create a little more space for the owners stuff. A poor choice looking at my skinned knuckles.
