09-20-2011, 12:21 PM
#1
Oil level relative to filter
I want to pull and inspect my oil filter without draining the oil. Clearly it mounts above the lowest level of the sump, but, if I remove it without draining any oil, how much will I be seeing when the filter is pulled? (Not sure this makes a difference, but I have a spin-on oil filter adapter.)
Also---anyone know of an "easy" way to open up the metal casing on an oil filter?
09-20-2011, 12:54 PM
#2
Porscheectomy
No oil from the sump will drain. Only what's in the filter and some oil from the pipes that feed the filter.
09-20-2011, 01:03 PM
#3
You will only lose oil volume equivalent to the filter itself and a couple tablespoons from the adaptor; less than a quart total.
As for the filter, you will need a good filter cutting tool:
Drop me a PM if you need specifics.....................
09-23-2011, 11:22 AM
#4
Well here I was thinking of using a good old fashioned can opener for this.
09-23-2011, 11:36 AM
#5
Swiss Army Knife can opener might work, but it would probaly take a while.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
09-23-2011, 01:08 PM
#6
It can be done with a very large tubing cutter, which would be somewhat “agricultural”. Good filter cutters don’t cost that much and last just about forever.
09-23-2011, 01:16 PM
#7
I used a hammer and an old, expendable wood chisel. It was not pretty...
09-23-2011, 01:30 PM
#8
I rest my case....................
09-23-2011, 02:10 PM
#9
Hey, what can I say? I was in a hurry, it worked, and I managed not to lacerate myself on any of those jagged edges. Those things are some kinda sharp! :dance:
09-23-2011, 03:28 PM
#10
How do you differentiate between the metal debris created during your “man invents tool” experiment, and the stuff you are actually looking for?
09-23-2011, 03:37 PM
#11
Oh, a wood chisel (even this old one) is pretty darned sharp---it cuts about like a can opener, albeit leaving an edge that's a bit jagged. No debris created in the process.
09-23-2011, 04:05 PM
#12
I love creativity and ingenuity in action…….. Good job!
09-23-2011, 06:04 PM
#13
Porsche "Purist"
IMO just use the stock filter....
1987 924S. 2002 996TT. PST-2
09-23-2011, 06:13 PM
#14
Autobahn Glanz
A good set of sheet metal shears work just fine and don't leave any metal filings...it will leave a sharp edge  . I have a one that cuts straight and one that cuts in a circle, I even cut paper with them. Great investment to keep in your toolbox.
