Old 07-01-2005, 05:00 PM   #21
deliriousga's Avatar
Originally Posted by MLegere
Guys
I just replaced my Expansion Tank, Expansion Tank Cap, Thermostat, Thermostat Housing, H20 Pump. My car has only 56k on it. So far in the first 90 days of ownership I have spent 2640.00 On Maint :ah: In the next 3500 Miles The 60k Maint will be due that will be another 800-1000
Mike
Sounds like somebody needs to learn to play. 60K maintenance is a $150 job in 2 hours if you DIY. Very easy to do.
1966 Wife White/Brown Top
Old 07-13-2005, 06:26 PM   #22
I live in a hot and humid climate as well and notice the temp on my 2000 2.7 always runs straight up the middle. I too have found my coolant levels dropping and did indeed find a the the angry green fluid aong the bottom of the carpet. I know this may be a tank/cap issue which I plan on trouble shooting in detail immeidately on my own. I'm just curious if driving at this temp is safe for teh car. I also notice the fans blow kind of loud when the car is in park ideling, is this normal as well?l
So now my DIY list is:
60k service
Brake rotors/pads/sensors
Possibly a new overflow tank/cap
Remove the center console for painting
Can I fly anyone down?
RENNX is offline   Reply With Quote
Old 07-13-2005, 07:16 PM   #23
If it's down the middle of the normal temp marks, it's fine to run at that, just watch it and make sure it doesn't get higher. The higher temp area will make any tiny leak you may have a big one in a hurry.
For the fans, they will run faster at idle because there is no natural air flow from the car moving. The fans have to make up for that so they blow pretty hard at idle.
Old 03-06-2017, 02:23 PM   #24
Ovearheating and No heater
Wrong post. Sorry!
tjwebber17 is offline   Reply With Quote
