Old 08-10-2011, 04:01 PM   #1
odor and windshiels fogging when heater on
I am experiencing a foul odor and windshield fogging when my heater is on. If I have coolant seeping in through the heater core. How much $ to repair??
bartocollector is offline   Reply With Quote
Old 08-10-2011, 04:12 PM   #2
boxter s 2004
Forgot to mention I have a 2004 Boxter S.
Old 08-10-2011, 08:17 PM   #3
husker boxster's Avatar
I'm not sure what it will cost, but DON'T DRIVE YOUR CAR!! Those are the classic signs of the heater core failing and when it finally lets go, you'll have a pool of antifreeze in your passenger compartment and you'll have to shut off immediately. And this ususally happens at the most inopportune time.
As far as cost goes, members can speculate or relate what they paid but your best bet is to call your local indy shop and ask them. What you find locally is all that matters anyway. You could call the dealer to get a baseline.
1989 928 S4 5 spd - black
Old 08-10-2011, 09:01 PM   #4
Heater core replacement books out at 1.5 hrs so with a coolant flush and proper bleed, maybe 2.0 hrs. The heater core itself (assuming OEM) is about $360 retail but I have seem them online as cheap as $320 plus shipping. A gallon of the Porsche antifreeze is $35 retail if I remember correctly. I have one (it's a 1997) in the shop right now for this exact thing.
kcpaz is offline   Reply With Quote
Old 08-11-2011, 04:48 AM   #5
or...
you could just need to change your cabin air filter. Dead mice, decaying leaves etc. will cause a stink.
Old 08-11-2011, 02:14 PM   #6
Originally Posted by Burg Boxster
or...
But if your windshield is fogging up plus the smell, that's heater core.
Old 08-11-2011, 03:02 PM   #7
Topless's Avatar
fogged windshield and foul smell might be a heater core... or clogged condensate drains.
If it smells sweet it is likely coolant. If it smells musty/mildew it is likely just clogged drains.
Old 08-11-2011, 04:02 PM   #8
input
Thanks for the input.
Old 08-12-2011, 04:25 AM   #9
Good point. So Bart, Name That Smell.
If it happens to be the heater core, might as well take advantage of the coolant drain and change out the water pump.
