Old 06-24-2005, 02:25 PM   #1
weird noise
hello to all i'm new to the board
i have a question and it is, i hear a whining noise somtimes it doesn't do it all the time, sometimes after i have been driving for awhile or when i start up, i only seems to do it when the car is stopped and i'm fixing to turn it off or right after i start it. It also only seems to do it when the a/c is on. i read somewhere that it might be emission control. any help is greatly appreciated.
i have a 2001 boxster
thanks
McMetz is offline   Reply With Quote
Old 06-24-2005, 02:31 PM   #2
Because you only hear it when the car is stopped, I'm guessing it might be the radiator fan? My car also makes a slightly high pitch(but not loud) noise when the air is on and I am at a stand still......
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 06-24-2005, 05:15 PM   #3
deliriousga's Avatar
I don't know for sure with the Boxster, but in the 928 there is a separate fan that comes on when the compressor turns on no matter what the engine temp is. It also stays on after the car is stopped.
I've heard a fan in the Boxster that is similar in behavior. There are several fans in the Boxster system so I wouldn't be surprised.
Does it sound "bad" or not like a normal fan?
1966 Wife White/Brown Top
Old 06-24-2005, 07:44 PM   #4
i'ts not real bad and it does only seem to happen when the a/c is on
