Old 06-22-2005, 01:30 AM   #1
Cool Boxster Audio....HELP!!!
Hi all.....My 2001 S has the basic CDR 22 system with dash speakers only, does anyone know of an easy way of upgrading the speakers, Porsche are telling me to fit the bose now would cost ££££'S.....any advice?? I would like to keep the head unit and not chop up the dash....
Y2BOX is offline   Reply With Quote
Old 06-22-2005, 05:54 AM   #2
Brucelee's Avatar
Talking
The Bose would NOT be the way to go in my opinion. Frankly, they don't sound all that much better in the Porsche IMHO.
A quality stereo shop can help. The basic becker unit is kind of junk so if you really want high quality sound, I think you are on the way down that road of complete swap out. Another way to go is to add the amplifier that the Becher unit has in the 911s. That would help and there is room for it in the front trunk.
After that, a decent compromise is to add speakers to the rear. This can be done somewhat inexpensively and the sound addition is pretty good IMHO.
If you do a search here on this topic, you should come up with tons of good data.
Good luck.
Old 06-24-2005, 12:52 PM   #3
Thanks...I have decided to go for a set of alpine components, 17cm in the doors and replacing the dash speakers with alpine tweeters...also adding an Alpine amp to the front storage section.....I will let you know the results next friday when fitted.........Cheers........
Old 06-24-2005, 01:17 PM   #4
Good luck!
I am just about in the process of upgrading my audio in my '98 as well....Have all the components, just waiting on the door speaker gaskets to get started.Was going to have it installed by a professional, but I think I can do it alone....Focal 2 ways in the dash, Focal 5WS Subs in the door, Audson 4 channel amp and Nak head unit.....Should be starting soon!
Show some pics of the completed project if ya can!
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 06-24-2005, 03:51 PM   #5
Please post your change in sound quality with the new speakers. That is the quickest and easiest way to change things - just swap out the existing speakers! On top of that of course is add the rear speakers.
One question for the board - I've seen the threads on adding rear speakers. But I'm not clear if they need an additional amp, or if the existing head unit has two more outputs?
- X
xavier405 is offline   Reply With Quote
Old 06-24-2005, 09:03 PM   #6
donv's Avatar
The CDR220 head unit has add'l outputs for the rear channels - if you have a fader control on your unit, then you should be all set.
donv is offline   Reply With Quote
