Old 07-06-2011, 09:13 AM   #1
Windscreen latch repair help
Ok, I need to replace both latches on the rollbar as well as on one side of the widescreen itself. Does anyone have a step by step process for doing this?
Shotokan is offline   Reply With Quote
Old 07-06-2011, 11:01 AM   #2
drill out the rivets that hold the broken latches on. Let the piece fall inside.
Go hardware store, buy a cheap pop rivet gun (10$), and some pop rivets.
Place the new hardware on, pop rivet it. trim to length.
done
The latch on the windscreen can not be replaced as a separate piece. check ebay and get a cheap replacement.
2002 S
Old 07-06-2011, 12:55 PM   #3
How do you remove the old ones? Do you rivet from the bottom? Sorry Doc I am an complete newbie when it comes to repairs.
The dealership didn't even want to fool with it when it was in for an air bag check. I casually mentioned it to the service manager and he started talking about removing the covers, taking it apart, about $200 was his guess.
Old 07-18-2011, 02:38 PM   #4
you just drill the old rivet out. A small piece will fall inside and you are done.
otherwise break off the old one and pull the rivet off, careful not to damage the paint.
2002 S
