Old 06-17-2011, 01:52 PM   #1
jaykay's Avatar
LASO water pumps
How do all feel about this aftermarket part? Is it better quality than oem or worse. I am considering it as i will be changing it every few years so...
986 00S
Old 06-17-2011, 02:05 PM   #2
Not good; several reports around of them not making 2K miles after install. While a pump change on these cars is not all that hard, fresh coolant adds significant costs, along with the grief of bleeding the system afterwards if you do not have the vacuum filling system. You really don't want to skimp on the pump......
Old 06-17-2011, 09:28 PM   #3
Steve Tinker's Avatar
+1
Theres a couple of guys here in Australia who had early failures of Laso water pumps. When I changed out mine earlier this year, I decided to go the genuine article from Jake Raby's Flat 6 organisation in Georgia and had it shipped to me - got it within 7 days, awsome service. I'm good for another 3-4 years now without any worries.
Why would you go with aftermarket for such an important piece of hardware for only a few $$ more....??
2001 MV Agusta F4.
Old 06-17-2011, 09:56 PM   #4
Idaho Red Rocket 3's Avatar
I've seen some aftermarket pumps with metal impellers. What about those ?
2000 Boxster S
Old 06-18-2011, 04:33 AM   #5
I asked jake about that last week. They used to recommend the metal. Now they don't; when the bearings go bad, the impellers chew up the aluminum block. He says use plastic, but change it every couple years before the impeller breaks down.
insite
'99 Boxster
3.4L Conversion
Old 06-18-2011, 07:23 AM   #6
If someone's trying to save a few bucks, I can offer them the OEM water pump I pulled off my car a couple of weeks ago. Still looks good and I'll let it go cheap! And only 90.000 km and 10 years on it.
Old 06-20-2011, 12:39 PM   #7
jaykay's Avatar
Okay thanks guys was just wondering whether there was a better option than oem...maybe I'll buy Norm's pump since he has broken it in for me already
Do you guys take the front mount down to do it....kinda dislike swinging the engine down on floor and jack stand. My front mount is in great shape and don't need to pull it.
986 00S
Old 06-20-2011, 06:52 PM   #8
Just did the water pump and motor mount his weekend and it was a breeze. Taking out the mount makes changing the pump much easier and vice versa. Once you drain the coolant you can move the hoses to the side and and the mount comes right out. Then, the water pump is much more accesible and most importantly, you can use a torquue wrench on all the bolts.
I used the car's service jack to hold the engine up. Put it on top of a couple of pieces of 2X6 and I could raise and lower the with just finger pressure on the jack screw.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
