Old 01-11-2011, 12:54 PM   #1
Appropriate glue for convertible top?
Hi all,
My top fabric has disconnected from it's plastic attachment point below the rear window on the -vert top.
It appears to have been glued in place. Does this sound correct?
Can anyone point me in the direction of the appropriate glue? I see this on Pelican Prts. "Wurth Rubber Glue" for $20.
Wurth
Is that the correct substance to use?
Joe
P.s. During normal operation of my top, I can occasionally see a little daylight through the back-bottom-middle of the top. Upon closer inspection, I realized I could lift up and edge and slide a finger or two through. That's the extent of the disconnect. The top fabric appears in great shape, and with a light plastic polish the rear window is in good shape as well.
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
JoeFromPA is offline   Reply With Quote
Old 01-11-2011, 01:32 PM   #2
jcb986's Avatar
The glue you talk about is maybe the sealant that Porsche uses when they make the Top, it also should have stitches around the window. There's a guy in New York that will repair it correctly for $350.
Old Hippie Young Heart
Old 01-11-2011, 02:18 PM   #3
I've seen the stitching around the window, but the point of seperation on my car is down by the very base of the rear-middle of the soft-top. Can that area also be stitched? I thought it mounted onto hard plastic "rib", but maybe I'm wrong and will investigate further.
Old 05-11-2014, 12:10 PM   #4
Did you figure out what glue to use? I'm having the same issue
paulneto is offline   Reply With Quote
Old 05-11-2014, 12:55 PM   #5
Registered Boxster abuser
healthservices's Avatar
This will sound strange but it works great when used correctly and allowed to set up. In the past I've had this issue and used of all things used...
It is super strong and water resistant,
Just make sure the area is clean and dry. I used duct tape to hold the material in place while the glue sets up. let it sit overnight.
You can get this everywhere like Walmart, target, sears, drug stores....
Old 05-11-2014, 12:59 PM   #6
I have also used this with a cloth patch backing successfully on tears and holes on convertible tops.
Just make sure to use some tape on the outside of the tear to prevent the goo from leaking thru the hole while the glue sets.
Old 05-11-2014, 05:48 PM   #7
Use the 3M spray on glue. Follow the directions, only about 30 minutes work time. when you glue the fabric, be sure to pull it hard in the horizontal direction to avoid vertical creases.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 05-12-2014, 10:22 AM   #8
Shoe Goo is awesome stuff. When I installed my new top I used contact cement where adhesive was required.
'99 black 986
Old 05-12-2014, 04:58 PM   #9
Just to clarify, I would most likely not use this product to replace and install a new top. But it does very well for repairs.
Sent from my SM-T310 using Tapatalk
