Old 11-22-2010, 08:27 AM   #1
how to remove HVAC controller boxster
Hello,
i just purchased a boxster 2000 a month ago and i need to remove the HVAC control unit, as the lcd screen is bleeding. i tried to find instructions how to remove it but i couldnt find instructions how to do it. could someone here help me out?
thank you
harrydigital is offline   Reply With Quote
Old 11-22-2010, 08:38 AM   #2
you should be able to 'unclip' the kind of little decorative frame around it, and then you'll have a few screw to get the unit out itself..
vipola is offline   Reply With Quote
Old 11-22-2010, 10:20 AM   #3
sounds fairly simple. is the frame simple to unclip? or is there a special way to remove it?
thank you
Old 11-22-2010, 03:57 PM   #4
If you search, there are some very good write-ups on how to remove the unit. Once the side panels are off the center console, it is pretty obvious; if yours is on the bottom. If on the top, simply pry off the "horse shoe" with a plastic putty knife.
I've had mine apart a couple times moving all the units around.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 11-22-2010, 11:06 PM   #5
http://www.renntech.org/forums/index.php?/topic/18754-climate-control-lcd-display-replacement/page__p__95631__fromsearch__1#entry95631
LCD Rebuild kit:
http://www.modulemaster.com/en/services/climate_controls.php
