Old 10-17-2010, 12:40 PM   #1
Locked out!
2004 boxster, battery disconnected, doors and lids closed, door lock inoperative.
Help, need to open hood to reconnect battery... necessary to open door and actually DRIVE the car again...
Any help?
Thanks,
Dave
dave-o is offline   Reply With Quote
Old 10-17-2010, 01:22 PM   #2
Go fish
for a wire connected to the front trunk lock that is accessed by undoing the passenger side (US) wheel well plastic and finding it taped alongside the headlight pod. Pull it.
Then, at a opportune time, relocate that wire pull to somewhere it is more easily accessible like under the tow hook cover on the front bumper.
Old 10-18-2010, 07:36 AM   #3
Hi Mike,
Did you mean Passenger side?? OK, So I'm a knucklehead, I assumed it would be on the driver's side (as the interior controls are there... Anyway, good practice, got the left side all apart. Also, as a bonus, have to work around installed wheel.... right, lug lock tool is in the trunk... How am I doing so far?
Old 10-18-2010, 07:47 AM   #4
How much cost a Door window again?? :P
vipola is offline   Reply With Quote
Old 10-19-2010, 06:04 AM   #5
Success!
Dearest Mike,
Indeed, stainless wire loop, under RF wheel well, just where you said. Pretty stiff, had to use piece of line to yank it. Made up swedged piece of stainless wire rope to relocate as you suggested. Many thanks!
See my post today under 'general discussion' for the overall issue I have now.
Thanks for you expert advice,
Dave
Old 10-19-2010, 07:59 AM   #6
Glad to hear it worked out well
Now fix that door lock
Old 02-19-2016, 12:50 PM   #7
986 door faults
i have a 1998 boxter 2.5 i have a fault the both doors lock and wont re open i have to use the key turned to the right to lower window then reach inside to open door pull also the center console switch when operated several times will fail in the locked position i have to open the door handle to reset
anyone knows where to go next car central locking seams ok but locks both doors closed
pieman1281 is offline   Reply With Quote
Old 02-19-2016, 01:58 PM   #8
Steve Tinker's Avatar
Is this message in code? Are these "clues" cryptic?
I suggest you re write and use punctuation marks & correct spelling - you may then get an intelligent response ......
2001 MV Agusta F4.
