Old 10-10-2010, 12:34 PM   #1
IPD Plenum+Intake=CEL HELP
I installed the IPD plenum, TB, and Cold air intake. after driving the car the CEL came on. The code indicated MAF. Changed it and CEL went away and back again with less than 50 miles driven. This is very frustrating. Anyone know what to do? Im away from the car so cant read the codes. my intake filter is a paper filter from injen so its not that. This IPD install has been a pain in the A$$ so far due to the problems I have got from it.
thanks
2001 Boxster S
Gemballa front bumper/Aerokit I Sideskirts/H&R suspension/997 short shift/Schnell front&rear strut brace/Aluminum pedals and floor board//Traffic pro/Console Delete//LED exterior lighting//Exclusive Options Full Leather/19inch Ruf Wheels/European rear bumper with 550 mesh/Zientec spoiler/IPD Plenum//Cold Air Intake/Hardtop/Speedster Humps
Stunin_Stud is offline   Reply With Quote
Old 10-10-2010, 12:54 PM   #2
What code(s) are you getting?
Old 10-12-2010, 05:54 AM   #3
ppbon's Avatar
The IPD ...
... and the similar TechnoTorque should not generate a CEL when installed correctly.
You probably have a vacuum leak from a misaligned rubber connector (usually on the bottom where it's not obvious).
There are also vacuum lines and a vacuum check valve that connect to the rubber pieces that sometimes get overlooked.
Recheck all of your work.
Once you find the leak, correct it, the reset the CEL.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 10-12-2010, 08:04 AM   #4
+1 pedro
