Old 07-03-2010, 01:05 PM   #1
2004 Boxster S Anniversary Edition
I recently opened up the engine compartment to change my air filter to be surprised that it uses the 987 air filter. I bought a bunch of parts off pelican parts assuming that i have a 986 engine, including a bunch of oil filters and spark plugs.
My question is do i have a 986 or a 987? Do I have to return the air filter and spark plugs or will they still work on my 2004 Boxster S Anniversary Edition? The 987 uses the same oil filter but not the same spark plugs or air filter.
Thanks!
pyiap is offline   Reply With Quote
Old 07-03-2010, 02:18 PM   #2
If it's a 2004, it's a 987.
Old 07-03-2010, 02:25 PM   #3
Porscheectomy
The AE used the intake that mostly made it's way into the 987, that's one of the places where the extra couple of HP came from. I'm not sure on the spark plugs, but I'd expect Pelican to be able to tell you. Rest assured, your car is a 986.
Old 07-03-2010, 02:29 PM   #4
I stand corrected
Old 07-03-2010, 08:50 PM   #5
Yups just as said above.. Your car is a 986.. That '04 550 special edition has the newer 987 airbox... Mind snapping a pic and posting for us?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
