Old 06-11-2010, 04:30 AM   #1
Boxster windshield washer nozzle adjustment
The nozzle on my windshield washer outlet got knocked out of alignment. This might be a dumb question, but before I start fiddling with it to get it to spray on the windshield again, I thought I'd ask how to do it. Steve in VT
EvetsElous is offline   Reply With Quote
Old 06-11-2010, 06:50 AM   #2
Some are adjustable and some aren't. On my '97 I was able to adjust them by inserting a straight pin into the nozzle and swivel the jet around until it was aimed in the right spot.
This is a simple DIY task.
Aron
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 04-12-2018, 07:35 AM   #3
Aron
Resurrecting a super-old thread (I know) but I did search and for the small handful of relevant threads I found there weren't any applicable (to me) replies.
On my '98 the nozzles are adjustable and I am wondering what the "correct" spray pattern is. Presently it is uneven between the left and right nozzle. The spray from the right nozzle hits the very top of the windshield while the stream from the left falls just below the upper 1/3 of the windshield.
Since the nozzles can only be adjusted when the car is standing still but are typically engaged when the car is moving I assume there has to be some "compensation" for the effect of the oncoming air while driving.
My working hypothesis is that the stream is deflected downward somewhat while driving and that a "static" adjustment should compensate for that by aiming them slightly higher than the desired target location.
Am I overthinking this?
--alex--
Life's too short to drive cars you don't love
hockenheim is offline   Reply With Quote
Old 04-12-2018, 12:08 PM   #4
Racer Boy
Racer Boy's Avatar
Which side works best when driving? Adjust the other side to match that when you make the adjustment.
