Old 06-01-2010, 06:20 PM   #1
Cel P0453
My car is throwing the P0453. It was nice not having the CEL for a few months...
So the code is for the tank pressure sensor. I was reading up on this and some people have suggested that I try a new gas cap. I'm pretty sure the one one there now is from factory and it would be the cheapest and easiest attempt at remedying the situation. Anyone else have other ideas?
Viper5 is offline   Reply With Quote
Old 06-03-2010, 02:09 PM   #2
bump........
Old 06-03-2010, 02:32 PM   #3
any issues with fill up /fumes ?
extanker is offline   Reply With Quote
Old 06-03-2010, 06:23 PM   #4
No issues with anything like that. I just ordered a new cap with the .03 digits in the part number so I think thats the one that is the most recent. I will see if that fixes it. In case it doesn't, however, I just wanted to see if there was anything besides the sensor it could possibly be.
Old 06-04-2010, 06:39 AM   #5
Unfortunately, I’d be willing to bet that a new cap is not going to cure this problem. P0453 is the code for an excessively high tank pressure; usually bad caps cause the opposite problem. More likely, you have either a bad pressure sensor or vent valve in your EVAP system……….
Old 06-04-2010, 07:53 AM   #6
seningen's Avatar
grab a set of schematics and a DMM and check the voltage coming back from the sensor.
it should be about 2.5v -- if it deviates significantly == than you have
a sensor telling you something is up. you can't tell if the sensor
is bad or not.
if you changed the harness from original - there could be a pin out issue.
m
seningen is offline   Reply With Quote
Old 06-04-2010, 10:49 AM   #7
I got the car a couple years ago and haven't messed with the harness. The is the first P0453 I have gotten. So that pretty much means that the harness pin out issue would not be the problem right? I remember reading somewhere online about a similar issue with the harness but I believe that guy had recently changed something with it.
Old 06-08-2010, 02:20 PM   #8
Silly question...where does the rivet go in the gas cap area? I have a 2000 boxster s if it matters.
Old 06-09-2010, 08:17 PM   #9
anyone know?
