Old 05-21-2010, 01:47 PM   #1
CAM problem
My check engine light has come on three times over the last few months each time reporting a code relating to the CAMs - I'm not overly technical so don't know the specifics. Is this a common problem on 1999 Boxsters? I'm quoted around $1600 for a new CAM + oil change + labor. Just wondering if others have had issues with their CAM.
my1999boxster is offline   Reply With Quote
Old 05-21-2010, 02:24 PM   #2
What the Hell do they mean when they say "CAM"? I've been working on Porsches for over thirty years and never heard anyone knowledgeable describe a problem as "CAM"............did they mean Vario Cam units, Cam position sensors, camshafts, or what? Got any code readouts?
Old 05-21-2010, 02:37 PM   #3
RE: CAM Problem
Sorry, to clarify, problem with the CAM shaft. I don't know what the code is.
Old 05-21-2010, 03:35 PM   #4
we need a code to help
extanker is offline   Reply With Quote
Old 05-21-2010, 04:20 PM   #5
Many auto parts stores will read OBD-II codes for free. Write down the code(s) and post them here.
-james
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 06-24-2010, 01:32 PM   #6
RE: CAM problem
It took a while to get the code. The CEL # is 174. Any insight is greatly appreciated.
Old 06-24-2010, 06:16 PM   #7
If you had the specific P code it would be a little easier, but he Porsche Fault Code 174 is for camshaft adjustment on the passenger side bank (1-3).
-Jeff-
"I'm a glutton for punishment when it comes to my boxster"
'03 S/ PSS9/ B&M short throw/ EVOMS intake/ NHP full exhaust w/ headers / Cantrell MS custom tune
boxster_s_boy_34 is offline   Reply With Quote
Old 06-24-2010, 06:30 PM   #8
I retract that previous statement, all 3 p codes are the same, so your cam position sensor is out, or if the car runs like a dog, your cam(s) has (have) jumped timing somehow.
-Jeff-
Old 06-25-2010, 06:57 AM   #9
Can also be a tensioner gone bad, a Vario Can unit, and/or the cam position sensor. None are particularly hard, but may require both special tooling and knowledge. Couple hours shop time at most.........
