Old 05-17-2010, 12:36 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
Originally Posted by ChrisZang
Did you reconnect the electrical connector for the seat belt receptor buckle?
Plugs into the device under your seat
On your other note: If you're looking for a good excuse to buy a Durametric, it doesn't get much better than that
Haha, yeah it is a pretty good excuse. I just bought it a couple of minutes ago.
Im sure I plugged everything the way it was, Ill have to double check again then if you think thats the case.
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 05-17-2010, 02:30 PM   #2
If your main plug wiring isn't pinched, then I'd look at the seat belt buckle and its wiring next. It's easy to scalp that wire when you feed it throught the new seat, and the buckles themselves do fail.
Mark
'99 black 986
Old 05-18-2010, 10:41 AM   #3
When I bought my car, I had the child belt in the front. I disconnected at some point and my airbag light came on. I brought it in to the dealership for something and at mentioned it to them. They took their device out and changed a setting which deactivated the passenger side airbag signal (otherwise it would always be on). It is something that cannot be fixed with durametric. At least this was the case with my professional version, but I haven't updated to their new one so maybe they can do that now although it is doubtful. Durametric is awesome, but it is still limited.
Viper5 is offline   Reply With Quote
