Old 05-09-2010, 09:23 AM   #1
Noise after Upper Rear Track Arm Replacement
I replaced my upper rear track arms, that were causing a clunk, with adjustable arms from Hardrace on my 55K mile 2003 boxster. The clunk is gone and the ride is much stiffer. Now I have a rattle that is audible when going over bumps at speeds under 25 mph. The rattle occurs from each rear wheel and appears to come from behind either the passenger or drivers head depending on which wheel is hitting the bump. I think the noise is being transmitted up by the shocks. Has anyone had such a problem after changing to the stiffer track arms? Any assistance would be appreciated.
dragonflyoh is offline   Reply With Quote
Old 05-09-2010, 05:29 PM   #2
ChrisZang's Avatar
did you replace them with "race" arms, which have no nylon bushings but metal bushings. In this case the noise would be normal
Old 05-09-2010, 08:09 PM   #3
Those arms shouldn't really make that much of a noticeable change as to what you're describing.
Double check that you have tightened down the locking nuts properly on the adjustable ends, and that they're not touching anything else.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 05-10-2010, 12:58 AM   #4
Sounds like the same problem on mine??
I was told by Zentrum that it is the "Lower Control Arm Bushes" that are the cause, they crack or corrode and will rattle like mad, especially if you drive over cobbles. It should not cause any handling issues though.
I was also told that you can't physically see the problem on the bushes and it only manifests when assembled and the car is moving.
http://www.hartech.org/parts.html do a £90 replacement part which I will try someday otherwise its a £200 part if going original.
Was told to get both rear sides done as they often go together.
Anim is offline   Reply With Quote
Old 05-10-2010, 05:24 AM   #5
Dragonflyoh, those lower, longest track arms do go out and cause the noises you are speaking of. Might be the newer, tighter adjustable uppers are giving the lowers the room they need to rattle now. It's always a slippery slope.
Vertex sells them with polyurethene bushings that should not wear out as fast as factory ones:
http://www.****************************************.com/ShowItem/128301%20Porsche%20Rebuilt%20Control%20Arm%20-%20Rear%20Track%20Arm.aspx
Old 05-10-2010, 01:00 PM   #6
The part I replaced is index number 8 in the attached drawing. I was thinking I might hear from someone that actually replaced their arms with the adjustable arms and hear what sort of experience they had. I am thinking RandallNeighbour may be on to something with the slippery slope. RandallNeighbour are you saying that index 17 may be causing the noise?
Old 05-10-2010, 02:34 PM   #7
ppbon's Avatar
Many times the rattle comes from...
... worn drop links.
If you can manually twist the droplinks with the car on its wheels, they're probably toast.
Good droplinks should be very difficult to move by hand because the joints are tight. After the joints wear they can generate a loud rattle when going over bricks, pavers, etc.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
