Old 04-21-2010, 12:41 AM   #1
5w-40 is on the updated approved porsche oil weights....
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 04-21-2010, 12:47 AM   #2
I don't know a lot about oil, but if the container says "Turbo" and "Diesel" and my car is a naturally aspirated petrol engine, I would probably use a different oil.
Daniel R is offline   Reply With Quote
Old 04-21-2010, 06:21 AM   #3
I would say the quick answer is NO. I was told to not use 5W anything in a Boxster.
My guess is you haven't read this:
http://www.lnengineering.com/oil.html
I would not use 0W40 period, let alone Mobil 1.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-21-2010, 06:46 AM   #4
litteng's Avatar
Delvac1 not mobil1
for years the only oil available from mobil1 in a 5w40 (in north america) was delvac1 5w40. it is diesel and gasoline engine rated . better still it was not energy saving rated, and at one time still had the higher levels of antiwear desired for good camshaft life.
i have a 99 passat 1.8T that ran exclusively on it for 250,000 km,
the mobil1 5w40 diesel rated oil may be okay, but you need to do some of your own homework and start reading and comparing what oils are recommended and what the oil of choice is offering , lastly
please lets not make blanket statements about something without checking first... the mobil1 diesel 5w40 may be nor in tune with what a porsche needs ....
i'm looking for a3 ratings
claus
03-r1100s, 11-f800st, 09-987.2, Norton Commando
auf adlers fluegeln getragen
litteng is offline   Reply With Quote
Old 04-21-2010, 07:30 AM   #5
I am sorry I made a mistake, I was told never use 10W anything rather than 5W. Sorry for confusion.
Also i agree mobil 1 is not the best. I use royal purple.
2002 S
jhandy is offline   Reply With Quote
