Old 04-20-2010, 06:32 PM   #1
Shift Knob
Does the shift knob on a 97 Boxster screw off or pull off? I am replacing the boot and plan to reuse the shift knob. Thanks.
Bradster is offline   Reply With Quote
Old 04-20-2010, 06:45 PM   #2
I assume it is like later years where the knob pulls straight off. They are on quite tight and require a pretty good force to pull upward...be careful not to knock your teeth out in the process!
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-20-2010, 07:49 PM   #3
kyleturner2020's Avatar
I just changed mine out today. trim just popped up, loosened a hex tension screw then slid it easily off. I have an S model. The boot was zip tied to the shifter...if that helps at all.
Kyle
2000 Boxster S
2007 H3
kyleturner2020 is offline   Reply With Quote
Old 04-21-2010, 01:06 AM   #4
Thanks, Guys. Sounds simple enough. Of course, that it what I said about my last project!
Old 04-21-2010, 02:44 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
After you lift the base of the boot off, you just pull off the knob if it's a standard knob. If it's an upgraded optional knob, there's a set screw that you have to loosen at the forward underside of the knob.
