Old 04-05-2010, 07:13 AM   #1
Brake Fluid
I'm planning to flush my brake fluid out of the system. I would like to know if it is OK to use the regular DOT 4 brake fluids available in Pepboys or Salvo. I have 2002 base boxster with automatic transmission. The Porsche dealer close to my area was closed for business and the nearest is 60 miles away. Thanks
itoy is offline   Reply With Quote
Old 04-05-2010, 07:51 AM   #2
tonycarreon's Avatar
buy online. probably cheaper anyway.
Old 04-05-2010, 08:03 AM   #3
pboxstercar
Posts: n/a
"break fluid" - Do you mean BRAKE fluid? I hope your mechanical skills don't BREAK your car.
Old 04-05-2010, 09:37 AM   #4
landrovered's Avatar
Break Fluid = Scotch or Bourbon
2001 Boxster S 3.6L, Zeintop
Old 04-05-2010, 09:51 AM   #5
boxster6354's Avatar
DOT 4
If flushing buy a different color than what you have, if Gold buy Blue, easy to tell when old fluid has flushed.
http://www.pelicanparts.com/catalog/shopcart/986M/POR_986M_BRKhyd_pg4.htm#item21
Old 04-05-2010, 10:23 AM   #6
jcb986's Avatar
If you are doing a flush, first check the color in your reservoir. If it's pale or yellow looking, get the blue. This way you can see the color change when bleeding. 1 can will do the trick.
Old Hippie Young Heart
Old 04-05-2010, 10:32 AM   #7
I used Prestone DOT 4 on my '02 986 and had no issues.
'08 987S, 6 Speed, Guards Red, Black Interior, 19" Chrome Wheels, Clear Bra, Painted Side Vents, Dension Ipod, Clear Side Markers, Cayman Sports Tip, Red Tail Lights
r9i8c7k is offline   Reply With Quote
