Old 04-12-2010, 03:34 AM   #1
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by S3adrag0n
Ok, just drove home, and then opened my trunk while engine still on, and took a listen. Absolutely no hissing noise from the oil cap area that I could detect. My oil cap is on tight. I did hear a little gurgling noise from the coolant tank though.
With the oil cap off or on? Mine is sucking air only with cap off; has no CEL or smoke and drives fine. I am a bit confused myself. I hear should not be sucking air and I also hear sucking air is OK with cap off.
As my post stated, "my oil cap is on tight."
Old 04-13-2010, 10:10 AM   #2
Mine doesn't hiss either with the cap on. Sounds like it's normal to have some air sucking with cap off: http://986forum.com/forums/showthread.php?p=211155#post211155
S3adrag0n
S3adrag0n is offline   Reply With Quote
Old 04-14-2010, 06:56 AM   #3
Well, I guess since a few of you have stated that your caps are silent in the fully-closed position, this confirms that I have a problem.
If/when I get the CEL again, I will get the code... I'm planning to get more driving in now that the weather is REALLY getting nice!
dja1980 is offline   Reply With Quote
