Old 01-26-2010, 09:00 PM   #1
ChrisZang's Avatar
Top swap DIY
does anyone have a DIY for swapping the whole top assembly (with frame) etc?
Old 01-26-2010, 09:43 PM   #2
It's DIY (Do It Yourself), not DYI.
gschotland is offline   Reply With Quote
Old 01-26-2010, 11:08 PM   #3
There Is No Substitute.
rick3000's Avatar
Mike Focke's site has a complete DIY guide, I believe Boxtaboy has done it.
Old 01-26-2010, 11:14 PM   #4
http://986forum.com/forums/showthread.php?t=20414
Old 01-27-2010, 12:30 AM   #5
three bolts and a small screw on each side... easier to do with the clam shell of so no scratching... i've done it twice... where are you located may be able to help if you need it... not to bad at all....
mikes_box is offline   Reply With Quote
Old 01-27-2010, 03:56 AM   #6
07 Carrera S Cab
Boxtaboy's Avatar
Yep, have done it on my 01 when we put an 03 top with glass window on. Here's everything you need to know about top transplants....
http://sites.google.com/site/mikefocke2/thetop-itsmaintaince%26replacement
Old 01-27-2010, 06:05 AM   #7
if it is just swap of the top, it is probably the easiest ting to do on the boxster, even simpler than an oil chance!
kabel
kabel is offline   Reply With Quote
Old 01-27-2010, 10:03 AM   #8
The toughest thing is finding one at a decent price!
Old 01-27-2010, 10:09 AM   #9
rick3000's Avatar
I was reading over Mike Focke's site, and one thing is still unclear. Can you in fact put an 03-04 top and frame on a 97-99 that has the old transmissions, switches, etc. and not change anything and have it work properly?
Old 01-27-2010, 10:51 AM   #10
07 Carrera S Cab
Boxtaboy's Avatar
No- the 03-04 top is a plug and play drop in to a 2000, 2001, and 2002 Boxster, but in order for it to work in a 97-99, you have to do a couple of modifications in order for the control unit to understand when to stop cycling the top. It is very doable though, and Maurice (schoir is his handle here), has done it on his 97 Boxster, and it works perfectly. I would contact him for instructions if you source an 03-04 top.
