Old 12-03-2009, 07:06 AM   #1
landrovered's Avatar
Newb question
New to me 98 boxster is doing something unexpected. The running lights are flashing on their own accord as if the hazard button has been pushed but it has not. I does it on start up occasionally and after the turn indicator has been used but not always. Both sides and front and rear are flashing.
Thank you for your help.
landrovered is offline   Reply With Quote
Old 12-03-2009, 09:26 AM   #2
Just a wild guess. Do a search on the ignition switch. I have heard that when it begins to fail some really weird things start to happen with the electrical system.
2000 Boxster S
1984 Carrera
1976 912E
1997 E36 M3/4/5
http://i713.photobucket.com/albums/w...ygug/arial.jpg
gerrygug is offline   Reply With Quote
Old 12-03-2009, 09:29 AM   #3
That would make perfect sense since the ignition switch is on it's way out. Thanks for the quick reply.
Any suggestions on where to purchase, I am not up to speed on the good parts houses for Porsche. I can tell you anything you want to know about a land rover though.
Old 12-03-2009, 09:30 AM   #4
I would check the flasher relay and the hazard switch.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 12-03-2009, 09:35 AM   #5
The hazard switch seems to be functioning properly, I can hear the relay/timer clicking. I could not figure out how the timer would get energized unless it was coming from the power source somehow but the ignition switch would 'splain it and it is definitely faulty.
Old 12-03-2009, 09:37 AM   #6
http://e-partssales.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=P&Category_Code=POTEBX
Here is a good source for parts.
2000 Boxster S
1984 Carrera
1976 912E
1997 E36 M3/4/5
Old 12-03-2009, 09:40 AM   #7
Wow and the part is reasonably priced, awesome!
