Old 03-12-2005, 06:40 AM   #1
Porschekid's Avatar
Rust warranty question...
Does the rust warranty on the car transfer to any new owners for the 10 year span? Would the rust warranty cover rusted lug bolts? I assume they aren't part of the body and therefore wouldn't, but I'm not sure. My front lug bolts on both sides are a rusted for some reason and sort of an eyesore (no problems with the rear ones). I have the 18" turbo twists on my car if that makes any difference in what size/type I need. If you don't believe it would be covered then where is the cheapest place to get some new ones?
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
Porschekid is offline   Reply With Quote
Old 03-12-2005, 07:34 AM   #2
Brucelee's Avatar
Talking
The rust warranty does not cover lugs. They are covered within the normal 4/50 warranty.
Old 03-12-2005, 07:42 AM   #3
Porschekid's Avatar
Rats. Ideas on where to get some for a good price? Would be nice if I could find ones that won't rust so easyily.
Well, it better be.
Old 03-12-2005, 02:20 PM   #4
I've discovered a couple of rust spots under the paint below my passenger side engine vent.
Can I get this fixed under the 10 year rust warranty? I'm the third or fourth owner.
Old 03-12-2005, 02:22 PM   #5
Brucelee's Avatar
Talking
Check the warranty language. I THINK this covers rust through and not just rust spots.
Let us know what you find out!
Old 03-12-2005, 05:42 PM   #6
Rusty wheel bolts are common. Porsche was replacing them under the 4 year warranty.
There are 3 wheel bolts that have been used. The part numbers end in 00, 01, and 02. 00 was the first version. I assume 01 is less prone to rust. 02 started in 2004 and is used on the new Boxster. The bolt head is smaller on 02 so you are not supposed to mix them with 00 or 01 bolts on the same wheel do to weight reasons.
Some guys just remove the rust and paint them. I bought some when I removed the locking bolts and they were less than $6.
Rust below the vents and door strike also can happen.
Old 03-12-2005, 06:16 PM   #7
Brucelee's Avatar
"Some guys just remove the rust and paint them."
This is what I would do if I had a free afternoon. Good rust oleum job and problem solved!
Old 03-14-2005, 04:28 AM   #8
Porschekid's Avatar
If I paint them or something wouldn't it just rub off when I put them back on?
Well, it better be.
Old 03-14-2005, 05:33 AM   #9
Brucelee's Avatar
Talking
I THINK you can get some forms of rust oleum that will work. I believe the originals have a coating on them which obviously didn't work very well.
You might try wire brushing off one lug and see what it looks like?
