Old 10-20-2009, 07:10 AM   #21
Unfortunately, lubricants – much like politics or religion – appear to be a difficult subject to have a dispassionate or objective conversation about………….
Old 10-20-2009, 08:32 AM   #22
I replaced the gear oil at 60k miles in my Mazda with Royal Purple and I'm satisfied with the purchase. It's slighty smoother especially when cold. The shifter feels like a warm knife cutting through hot butter. I just wish the shifter in the Boxster felt half as positve, smooth and easy to shift. Since it yielded an improvement in the Mazda(even though it shifted well from the start) I might try it in the Porsche if they offer the correct weight.
Old 10-20-2009, 10:54 AM   #23
Originally Posted by Brucelee
Again, I fail to understand how the above statement can be made and not seen as "personal preference."
Its information found in the Porsche manual, not in Frank's manual.
Also the original post was for a vehicle used in everyday service, its not a track vehicle.
Porsche's recommendation are not for track vehicles, and neither are mine.
You are on your own with a track vehicle.
NH
Frank M is offline   Reply With Quote
Old 02-10-2010, 09:09 AM   #24
I'm checking into gear oil for the Porsche trans and I'm on Redline's site. They recommend their GL-5 75W90 oil for Porsches not the GL-4. This is contradictory to what some of you are saying. I'm confused. Here is the link.
http://www.redlineoil.com/Products.aspx?pcid=7
Old 02-10-2010, 10:32 AM   #25
The problem is that you would normally use a GL4 in the transmission, because as I understand it most GL5s are corrosive to the soft metals found in there (copper, brass). However, the Boxster uses the same lube in both the tranny and the differential, and the diff has hypoid gears.
Redline specifically says that their MT-90 GL4 is *not* for use with hypoid gears. They also say that their GL5 is formulated so it is not corrosive to soft metals. That's why they recommend their 75W90 GL5 for the Boxster.
Having said that, I was told by a 'reliable source" that the MT-90 was just fine to run, and I did. My shifting smoothed out, and I never had any issue with gear noise over 20k miles of use. But if I still had the car I'd swap it over to the GL5 lube, just in case.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 02-10-2010, 10:57 AM   #26
That's what I needed to know. Thanks for the info Jack.
Old 02-10-2010, 04:42 PM   #27
I wouldn't trust it.
Suppose one of your syncros fails and you get an occasional grind.
It will cost mucho bucks to fix.
I would buy the Porsche lube to have piece of mind rather than experiment.
NH
Old 02-10-2010, 05:29 PM   #28
My mechanic is a Porsche certified tech and put Royal Purple gear oil with the appropriate weight in my 5 speed manual tranny after I swapped it for one that had a bad 1st gear synchro.
Boy howdy, if you want to kick up a dust storm, just ask about oil or tire preferences on this or any sports car forum!
Thankfully, most all of us agree on the best fuel to put in the car...
Old 02-10-2010, 05:49 PM   #29
I still stick with the engineers.
Techs have opinions and usually not accountable, engineers are accountable.
I can hear a tech saying your syncro is gone because you mashed gears.
Well the gears will mash when the syncro does not bring the new gear up to the same speed as the driver gear. This causes damage to the syncro cogs.
NH
Old 02-10-2010, 08:41 PM   #30
I understand your position, except:
RMS seal failure. IMS bearing failure. D-chunk cylinder liner failure. Premature AOS and oil filler tube failures. Rear axle bearing failure. Etc, etc,...
All Porsche engineering failures. And they have NOT been held accountable.
Jack
Old 02-10-2010, 08:54 PM   #31
All things have flaws and failures.
Imagine if techs designed cars.
Would anyone want to fly in an airplane designed by engineers or mecahnics.
Who would drive on a bridge designed by excavators.
Who would want to have their teeth drilled by the dental assistant..
NH
Old 02-11-2010, 04:26 AM   #32
All true, but...
Porsche doesn't "design" oil. They don't manufacture it, or even package it.
The guy that designed the tranny writes up a spec for it, and the lowest bidder gets a contract to supply it in a bottle that has the Porsche name on it.
Redline engineers design and produce nothing but oil. That's their field of expertise.
Hmmm... in a way, the Porsche oil is a bit like the bridge that was designed by the excavators.
YMMV.
Jack
Old 02-11-2010, 05:11 AM   #33
All true, but...
Then why do lubes have a manufactures spec?
such as :
Mobil 1 0W-40 keeps engines starting in Arctic-extreme cold, and it cleans deposits, sludge and varnish often formed in high temperature operating conditions.
Mobil 1 0W-40 meets key industry and car builder specifications for:
− Mercedes MB 229.5
− Porsche Approval List 2002
− GM-LL-A-025 (gasoline)
− ACEA A3, B3/B4
− BMW Longlife 01
− VW 502.00/505.00/503.01
− GM-LL-B-025 (diesel)
− API SM/CF
NH
Old 02-11-2010, 05:20 AM   #34
such as :
− Mercedes MB 229.5
− ACEA A3, B3/B4
− BMW Longlife 01
− API SM/CF
It's called marketing.
Notice how Mobil 1 meets so many specs? That's because there's not 2 cents worth of difference between them, and it's not rocket science to meet them. But, as we know when it comes to getting a manufacturer's blessing (think Porsche approved tires), there's a cost involved in getting that blessing. Not having it doesn't mean you don't meet, or exceed it. As a manufacturer of oil, you pay for the privilege of putting that spec on your bottle. It's about money.
Jack
Old 02-11-2010, 05:25 AM   #35
I hope this isn't developing into an AMSOIL or REDLINE thread.
NH
Old 02-11-2010, 07:08 AM   #36
Lord, no. Wouldn't want to steer it away from the "OEM only" thread it's become!
Jack
Old 02-11-2010, 01:32 PM   #37
tnoice's Avatar
Originally Posted by 941MXVET
This statement officially says nothing. No substance, just drink the kool aid!!
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
