09-29-2009, 11:48 AM
high mileage boxsters?
I'd like to see a list of people who achieved many miles without major failures...
09-29-2009, 12:09 PM
My97
Just got mine thursday 133,000 miles and burning a lil coolant but still running
09-29-2009, 12:17 PM
No major failure, you mean the car/engine is still running? I have 90K on my 2000 base and have been shaking up the poor little 2.7L engine with a lightweight flywheel for almost 40K now. Its a good thing its a convertible, because I keep looking up to see when the sky is going to fall.....
Ed
My Car Webpage
09-29-2009, 01:07 PM
Cool, I have an 02 with tiptronic and 52,000. I love the car but got a little nervous reading the engine failure posts. sounds like Raby has a preventative fix.
I was sure there had to be some boxsters with lots of miles....
09-29-2009, 01:12 PM
1998 2.5L with 83k miles, 2nd owner, well maintained, stock original motor, trans & clutch, and never a drop of oil on the garage floor. She now has about 25 AX/track days with the only significant expense being tires, brakes and gas. We just did a thorough inspection on the whole car and she came through with flying colors. Still quite a sweet ride.
09-29-2009, 02:00 PM
I have a 2002 2.7 manual with just under 80,000. I have put on 16,000 of that as the second owner. All original equipment. The only repairs I have made are a brake light switch, replaced the A/C display, and a right front marker light bulb. Runs great. Accelerates in 5th gear like no vehicle I have ever driven.
As for oil leaks, to quote Johnny Bench from an old Krylon Spray Paint Commercial, "No runs, No drips, No errors."
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
09-29-2009, 02:52 PM
We've seen several with higher mileages. We've done valve cover re-seals on some, a starter or two, head gaskets on two, lots of water pumps, an alternator or two, plenty of clutches but generally the cars seem to hold up well. Only concern for a car that is running well is the IMS bearing, which we recommend updating with the LN part.
09-29-2009, 03:11 PM
Highest '02 base I know of is around 230k miles by now
and a daily driver. Heck he has taken it on 5k+ trips after 200k. No work inside the engine.
So can your car go on forever? Darn near. He changes oil every 5k and pretty routine stuff other than that.
09-29-2009, 06:58 PM
Rennzenn
2000 S with 124,xxx miles. I bought it in Feb '06 with 60,000 on it. I change the oil every 5,000. I've added headers, guttted the cats, and opened up the muffler (the sound is phenomenal!). I also added an EVO intake with AEM dry-flow filter. The struts were replaced with K-sports, and I've got R-comps for AXing. There are a few other mods here and there.
I've AXed the car for 3 seasons, winning the Boxster class with the local PCA, and finishing in the upper third with the SCCA and another local organization. No babying here.
She runs great, doesn't use much oil, and hasn't given me any headaches other than the expected stuff: AOS, CV boots, MAF. Oh yeah, original coolant tank and clutch!
09-29-2009, 07:17 PM
2005 2.7L with 76,600 miles. Basic maintenance and one AOS replacement.
The car's still a blast to drive and driven nearly every single day as it has for the last 4+ years.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
09-29-2009, 07:43 PM
I don't know if it is considered high mileage but here we go.
2002 2.7 5-speed. 87k miles. Its my DD and It sees all kinds of weather and driving conditions. Havent had any major probles yet... Knock on wood.
Just replaced the AOS, RMS slowly leaks, CV boots are starting to crack (this weekends project). Clutch biting point is prety high but doesn't slip yet. Fairly reliable car so far.
09-29-2009, 09:44 PM
97 with 128K. Second owner, no major services. Feels like I'm going to need a new tranny soon though.
Black 2000 986 5 speed w/turbo wheels
09-30-2009, 01:31 AM
Not Knocking on wood
Marine surveyers knock on wood to find out if there is any dry rot. I don't need to find anymore rot on our sailboat, it has plenty already.
2000 S with 103,000 miles, just the usual stuff and a finicky 2nd gear shift which I hear is fairly typical for these years. Bought it a year and a half ago and put 7500 miles on it. Just did my first DIY oil change and I appreciated all the jacking threads. Car is so low my floor jack wouldn't even go under it.
Got spoiled owning the van for so long. Didn't have to jack it up to change the oil on it! Just put down the cardboard and slide under it with a wrench and a pan.
FYI, don't waste your time with a Harbor Freight cap style oil filter wrench. It doesn't fit the Boxster oil filter housing very well. I was only able to get it to work by modifying it on the lathe to get it to seat deeper on the plastic housing. Most of you don't have access to a metal lathe.
Just bought a OBD II reader also. Now I can deal with those CELs without having to go to the shop or $tealership.
Met a friend for lunch last week and the waitress loved the Pcar. Didn't have to twist her arm to get her to sit in the car for a pic. This place blew me away, they have over 400 different kinds of bottled beer for sale and 700 different wines too, unreal.
09-30-2009, 05:44 AM
Likely just needs new syncros and a freshening. We've done a few of these.
09-30-2009, 05:59 AM
How much should I expect that to run me?
09-30-2009, 06:03 AM
I just bought an 02 Boxster with 70K on it, is there anything I should be worried about?
09-30-2009, 06:08 AM
Send us a PM and we'd be happy to provide you with a quote.
09-30-2009, 07:35 PM
Bought my base 01 in sep-06 with 60k miles. it now has 108k. only issues were a water pump ($700), ignition switch ($25 diy), and a taillight. it's a daily driver (90 miles a day). great car. oil changes at ******************************** bavaria every 5-7k miles. reliable.
10-02-2009, 07:43 AM
I'm in Seattle area, but I don't recognize the place (in the background?). Where is it?
2003 Porsche Boxster S - Speed Yellow (sold)
2005 Lexus LS430 ML
2006 Lexus GX470
10-03-2009, 03:02 AM
It's in downtown Renton, enjoy.
http://www.redhousebeerandwine.com/
"400 bottles of beer on the wall, 400 bottles of beer, opened one up, drank it on down, 399 bottles of beer on the wall...  "
