Old 09-22-2009, 07:14 AM   #1
CEL codes 1133 & 1126
got these codes,
what should be my first step, change out bank 1 O2 sensor before C.Coverter?
P0133 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Below Lower Limit
P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
01 Boxster S, 69,000 miles.
thanks for any help,
Scott
smay 01Boxster S
http://i75.photobucket.com/albums/i3...sterSrear3.jpg
smay01Boxster S is offline   Reply With Quote
Old 09-22-2009, 08:24 AM   #2
Sure the O2 is tired and needs replacing.
Any muffler shop can do it if you don't want to. My last cost $37.50 in labor. I used the Bosch OEM unit as it is the same part Porsche buys. http://mike.focke.googlepages.com/oxygensensors will give you the part numbers.
P1126 is most often an intake air leak.
AOS checked? Other hoses tight?
Done anything recently?
Got a K&N air filter or some other non-standard in the intake stream?
I'd fix the sensor and check the throttle body for oil and reset the CEL maybe even disconnect the battery for a half hour to cause the ECU to have to reset and relearn and drive for a bit and lets see what happens.
Old 09-22-2009, 10:47 AM   #3
thanks
only changed out air fliter with OEM one about 3K miles ago. I will look at changing out the o2 sensor myself and reseting the computer. I heard you only had to leave the battery off for 20 seconds and it will reset.
what about cleaning the MAF as well?
Thanks for good info!
smay 01Boxster S
Old 09-30-2009, 01:33 PM   #4
Does anyone know the difference between these o2 sensors?
http://www.speedyautoparts.com/find/PRBOXSTER96.html
I can't see paying $600 for o2 sensors. My car is saying they are all dead. I'll do a little work to save $450.
silver arrow is offline   Reply With Quote
Old 09-30-2009, 02:01 PM   #5
To be honest dude I'd take this chance and respec your cars DME(ecu) to RoW that way it only reads from 1 set of o2 sensors,the rears readings are deleted. You'd only have to pay to replace the first set of o2 sensors and the car will run on wider reading parameters so the CEL is less likely to go off from emissions readings.
Old 09-30-2009, 04:16 PM   #6
Who can reset my ECU to ROW? I'm down with that.
