Old 09-21-2009, 12:00 PM   #1
Soft clutch
Hey guys,
My clutch seems to be getting "soft"? Not as grippy. It's fine, meaning, I don't feel any slippage, but the engagement isn't as strong...
Does that make sense?
Opinions?
From what I read, you don't adjust the clutch
What can I test, without removing the engine?
'02 Boxster Seal Grey or is it Gray?
-Alexandria, VA-
BobMarley1 is offline   Reply With Quote
Old 09-21-2009, 12:26 PM   #2
Keith Newby's Avatar
You might consider bleeding the system. I hate to suggest it, because reaching the clutch slave cylinder bleed screw is kind of a pain. At least it might be a cheap fix if it gives you back the pedal feel you've lost.
Keith Newby is offline   Reply With Quote
Old 09-21-2009, 12:28 PM   #3
Originally Posted by BobMarley1
Hey guys,
Opinions?
No; but you do need to bleed/flush the clutch hydraulics every two years when you do the brake hydraulics..............
Old 09-21-2009, 12:32 PM   #4
okay
thanks guys, I've had it a while, and have never had that done.
Cheers!
-Alexandria, VA-
