Old 08-28-2009, 07:35 PM   #1
Took rear trunk carpet out and found this??????
Hi all,
Took out rear trunk carpet out to find a wire (looks earth) to be cut???
Would anyone know what it is for?? The vehicle drives fine and all works but am curious why it was snipped..
It's a '98 986, manual and it is all standard, no aftermarket accessories fitted..
Thanks in advance for your input.
Cheers Don..
Nuts 986 is offline   Reply With Quote
Old 08-28-2009, 08:32 PM   #2
It's a ground wire. To what, it is uncertain since you can't see where it goes. If you can, track down the other end of the wire and then you'd be able to tell what it's supposed to be grounding.
Boxster S
Old 08-29-2009, 02:33 AM   #3
looks to be something aftermarket since the ring terminal doesn't look oem... if it was stock it would have been tied together with the other wires on the ring terminal... just strip both ends and tie em together...
mikes_box is offline   Reply With Quote
Old 08-31-2009, 03:17 AM   #4
ok, i ended up joining the wires back together and tried the vehicle to see if anything would happen, what i noticed is that the rear wing would come up at slow speeds and retract whenever it feels like it...... very weird so i might just undo the wires and let it be...with the wires separated the wing still operates manually....never mind...thanks for your suggestions anyways.
cheers don
