02-26-2005, 07:38 PM
Top up or down for storage?
Ya'll:
Durnig this winter I've been driving my Box on nice weather days, typically when I can put the top down. It seems like I've been able to take her out at least once a week. When I am garaging it during the bad weather intervals, am I hurting anything if I keep the top down? Keep in mind, the top is dry when I park it and it's in a garage.
Thanks guys!!
Gus
02-26-2005, 07:56 PM
You didn't say whether it was a plastic window or a glass window top.
The only negative I can see to storing it with the top down is the possibility of a plastic rear window taking a "set" from the low temperature. I'm assuming your garage isn't heated, too.
I'm also assuming that the storage period wouldn't be extensive in any case, maybe a few days or a couple of weeks at the outside.
If it were an extended period, several weeks or months, I believe you would be better off to store it with the top up.
02-26-2005, 07:57 PM
I don't believe you are going to hurt anything by doing that. More dust will accumilate inside the car but other than that you should be fine. I have the top up when I store mine for about 4mo and also cover it to protect from dust, but the rest of the year it usually sits in my garage with the top down.
02-26-2005, 08:02 PM
It's a 2004, glass rear window. I also have a cover over it for the dust issue. In a previoous unlightened life I had a SAAB Turbo convertible that had issues with the top. I didn't want to take any chances with new Box.
Thanks for the replies
Gus
02-26-2005, 08:13 PM
What kind of problems did you have with the SAAB top?
No reason to think Porsche tops would necessarily be immune to problems, particularly since most of the Boxsters and the SAAB convertibles are/were both made by the same outfit (Valmet) in Finland.
02-26-2005, 08:22 PM
After a year or so.. I started to get "read thru" of the frame under the top through the top. It's like the top shrunk or something. You could see more easily the metal ribs spanning across the convertible top. You'd think the fabric on the top would be less stressed with the top down and the opposite would occur.
Gus
02-27-2005, 06:01 AM
I'd personally say top up - saves all the creasing of the fabric.
Just realised mines been down for 5 months now with the hardtop on - be interesting to see how creased it is ina few weeks time.
02-27-2005, 07:09 AM
I purchased a Box with a hardtop once. When we pulled it off, the soft top was basically trashed. The window was gone as you would expect. The top had creases that would not come out and the color was distorted where the folds had been.
My advice is to keep it up when storing and put it down when driving. The movement is good for the frame/motor also.
02-27-2005, 08:16 AM
I agree Brucelee. I had not thought about the importance of exercising the linkage and the motor as well. Good thoughts guys, thanks for your imput.
Gus
02-27-2005, 12:11 PM
top up. Keeps the bugs out
I don't ar how clean your garauge is, a spyder can climb in and under a car cover
02-28-2005, 07:50 AM
Don't forget the Hardtops
Those of us who live in cold areas and have hardtops keep the ragtop down all winter. No issues, yet...
