Old 07-15-2009, 10:21 AM   #1
Dashboad cluster voodoo
Going back and forth b/w kilo and miles each start-up. And some freezing - gas and oil warning lights on with no movement of the speedometer.
A light tap to the top or face of the cluster fixes it for a time. Should I just swap out the cluster, check wiring, any suggestions?
Also for a 2001 cluster - what other MYs will work? Part number?
996641 213 00?
urban_legend is offline   Reply With Quote
Old 07-15-2009, 10:52 AM   #2
you can buy my 2001 S cluster for 100 shipped if you want
BoxsterLewis is offline   Reply With Quote
Old 07-15-2009, 11:11 AM   #3
996641 213 00?
Are you having any issues with your ignition switch? Similar problems have been seen when the switch was on its way out............
Old 07-15-2009, 06:16 PM   #4
I am having similar gauge craziness on my 987. Factory manual and Durametric with no clear answer.
"communication problems" is about as clear as I can get.
Let me know if replacing the cluster helps.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
Old 07-16-2009, 05:58 PM   #5
No other issues....
Ignition was repaired by the dealer several 4 years ago. At the time, the previous owner reported the cluster freezing. But of course didn't fix it.
Anybody know what clusters will wrk with a 2001?
It is morbid, but you can tell what survives in a crash by how low the parts price is at the dis-manterlers. Cluster behind the air bag is always in great shape even if the rest of the the car is totaled.
Old 07-17-2009, 06:58 AM   #6
My gauge cluster started this last week: Light on speedo not lit, one or two knocks on the front and it lights up. Clearly behaves like a loose connector, question is how easy is it to remove? Is it just easier to knock on the speedo of my most expensive vechicle with the silliest of failures?
