Old 06-10-2009, 02:45 AM   #1
x-drilled rotors cracking photo
I think this was brought up by Kirk, he said he has never noticed it before. Well...
It's from a 996TT after 6 DEs.
http://www.6speedonline.com/forums/2383623-post36.html
Old 06-10-2009, 04:47 AM   #2
This is common with cross-drilled rotors on all cars that are tracked. The prevailing wisdom (and one I trust) is it is a non-issue until you have a "significant" crack that connects one hole to another.
The rotor in your picture has insignificant surface cracking and nothing connecting the cross-drilled holes to each other. It isn't a concern at this point in the rotor's service life.
On a car I tracked often, I would not use cross-drilled rotors. Gas-slotted rotors perform just as well with less risk of failure due to cracking. That's what I used for many years on my 911 track car.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 06-10-2009, 05:28 AM   #3
Regardless, I just don't like the idea that the rotors need to be replaced before they reach minimum thickness.
I am reluctant to order the rear stock S OEM rotors since they only come in x-drilled unlike the base model rears which come in plain or x-drilled.
Old 06-10-2009, 06:01 AM   #4
A 996TT is a very heavy car and will generate a lot of heat under braking, especially if the driver is not highly experienced in using brakes for short periods of time (may or may not be the case here).
I agree with Lucky's comment that those aren't throw-aways just yet, but I'd certainly keep an eye on them for further cracking. Slotted is a better way to go for track cars with plenty of air ducting. I've been tracking 911s for years and have always considered rotors throw-away items and would purchase fronts by the half dozen.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 06-10-2009, 07:28 AM   #5
I saw a 944 S2 at the last DE that actually cracked the rotor so bad it was 'clicking' when the crack hit the pad.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
Old 06-10-2009, 10:58 AM   #6
That is not good. We had a 911 cup car lose it's front end at a very high speed braking point and crashed, when the front rotor exploded, due to what I could only assume was a crack that went unnoticed.
JGM
2002 Boxster S
Old 06-10-2009, 12:37 PM   #7
Who is the manufacturer of those rotors? They aren't Zimmerman because mine are not drilled as many times as those.
eightsandaces is offline   Reply With Quote
Old 06-10-2009, 01:00 PM   #8
They are 996tt rotors, not Boxster S.
-- John
'00 Boxster S
Old 06-10-2009, 03:48 PM   #9
Are they OEM?
Old 06-11-2009, 08:20 AM   #10
Brad Roberts's Avatar
John/Lucky nailed it.
This is normal, and that rotor is not even close to failing. The *only* difference I go by to John's post? We let the rotor cracks go from one to another, but discard the rotors when the crack's are 3-4mm's from the very edge of the rotor.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
