Old 05-20-2009, 09:36 AM   #1
Please help
I have 1998 boxster it need the oil separator but they are so many part numbers and I don't wish is the corect for my car. What is te dieence beetwen all this part numbers? 996-107-023-01, 996-107-023-04. Can somebody tellme please? Thanks
santpr is offline   Reply With Quote
Old 05-20-2009, 09:46 AM   #2
If you phone suncoast they should be able to help you. I have a similar problem with wheel carriers and they sorted it out
http://e-partssales.com/Merchant2/merchant.mvc?
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
Old 05-20-2009, 10:57 AM   #3
Porscheectomy
The last two digits in a Porsche part number are the revision. The higher the number, the later the revision. Typically, they will keep the part number the same except for the last two digits if the part is meant to be upgradeable on older models, for example a car that came with XXX-XXX-XXX-01 can use the XXX-XXX-XXX-04 with no problems.
If the part are not interchangeable, they will change numbers other than the last two. The MAF is an example where the XXX-XXX-125-XX is not a drop in replacement for the XXX-XXX-124-XX because and ECU reflash is also required.
I'm not 100% sure if this is the case with the AOS and contacting Suncoast is a good idea, but in general, this is the way Porsche PNs work and you probably just want the one with the highest final two digits.
Old 05-20-2009, 11:41 AM   #4
I was also told that a different revision does not necessarily mean a different part. If Porsche decides to subcontract the exact same part to someone else they still roll the revision (e.g. -01 to -02) even if there was no change to the part design.
Old 05-20-2009, 01:13 PM   #5
Porscheectomy
Interesting, usually design has part number and revision control but supply chain is a separate department with no control over drawings. Maybe that's different for Porsche.
Old 05-20-2009, 01:50 PM   #6
Thanks so much for the quick respond very happy. I just installed the 996-107-023-04 it working go so far. It took me like 30 minute it's wasn't bad are all.
Old 05-21-2009, 10:43 AM   #7
oh i agree. I was surprised when suncoast told me that. I work in the Aerospace industry and they don't roll the dash number for a revision unless there is a design change. Aerospace companies switch suppliers all the time with out changing the dash number.
Weird indeed but thats Porsche for ya :dance:
