Old 05-09-2009, 05:33 PM   #1
Cleaning MAF
Hi 2003 boxster 67,000km's.Is it ok to clean the MAF to maybe gain mpg and run smoother if there if there's no problems with engine?How hard is it as do i need special tools?Or just leave it if isnt broken.
eomak is offline   Reply With Quote
Old 05-10-2009, 06:31 AM   #2
it's ok to clean w/that mileage, though I doubt you'll notice any significant increase in mileage or anything else that tangible.
it's easy to do. the only "special" tool you need, iirc, is security torx bit; if you do a search, you can find the correct size. these bits can be found in most auto parts stores. you can also get some CRC MAF cleaner.
the MAF sensor is located towards the left side of the engine bay (driver's side) near the air filter assembly. you remove the 2 torx bits that hold the MAF assembly in place and carefully remove the maf. you then use the CRC maf cleaner to spray the tiny sensor clean (you don't want to touch the sensor). their are instructions on cleaning it on the CRC can as well.
-jimmy
jjanari is offline   Reply With Quote
Old 05-10-2009, 07:02 AM   #3
Thanks u for info.
