Old 04-10-2009, 12:00 PM   #1
Code P1126
OK, so I have searched on here and over at renntech for my CEL code P1126, which for my 2001 2.7 is Oxygen sensing adaptation, lower load range, bank 1. Does this sound like an oxygen sensor as it is only throwing one code? If it was the MAF, I assume codes for both banks 1 and 2 would be triggered. It came on about 5 miles after a fill up so I checked the fuel cap and it was fine. Before I go replacing 02 sensors anyone else have just this code show up?
FYI about a year ago I was getting P1128 and P1130 and found the hose going to the throttle body was almost loose, so that was probably an air leak. Replaced the spring clamp with a screw type clamp, cleared the code and haven;t had an issue until today.
shaman1204 is offline   Reply With Quote
