Old 10-20-2008, 10:21 AM   #1
CEL on (not flashing) and temperature light flashing...
What could possibly cause this combination? Is is possible the two things aren't related (even though both things occurred near simultaneously)? I'm a bit miffed at the temperature issue as I had the water pump replaced about 10 months ago. Any ideas?
kansaslawguy is offline   Reply With Quote
Old 10-20-2008, 07:06 PM   #2
Porsche "Purist"
Paul's Avatar
Start by checking your coolant level.
1987 924S. 2002 996TT. PST-2
Old 10-20-2008, 07:20 PM   #3
Low coolant level will cause the temperature light to blink.
Check your coolant level. Fill if needed. Then see if the CEL goes away. If not, go have it read and look up the code.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 11-02-2008, 09:22 PM   #4
Did you figure out what your problem is? I had the same thing happen. Temp light flashing followed shortly by a constant CEL. Don't mean to scare you too much, and I hope it isn't the same thing that happened to me but when my CEL came on it could have just as well stood for "Change engine light". My coolant ended up where it wasn't supposed to be and that tripped the oxygen sensor thus the CEL.
2001saxster is offline   Reply With Quote
Old 11-07-2008, 08:11 AM   #5
same problem
I was on the freeway when this happened.. the light temp. light flashing. so i exiting and the light stop. Weird!! but i will check my coolant level...
KATINZBOX is offline   Reply With Quote
Old 11-07-2008, 08:27 AM   #6
cel?
what is (CEL) that you guys mentioned about? i didn't get any of that after my temp light flashing!!
Old 11-07-2008, 10:02 AM   #7
Lil bastard's Avatar
CEL = Check Engine Light
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
