Old 10-01-2008, 06:47 PM   #1
Dex Cool Issues
On a 1999 Boxster, I wanted to use Prestone brand Dex-Cool. I have done a lot of searching and I've found that Havoline and Texaco DexCool are acceptable, but I can't find an answer on Prestone's version of DexCool.
Is it alright to use? Is there a better alternative? I can't imagine the two brands being that different, but I would rather be safe than sorry. I already purchased some Prestone Dex Cool, but I can take it back if necessary. All I seem to be able to find in the stores in my area is Prestone's version.
Thanks for the help!
jacob_coulter is offline   Reply With Quote
Old 10-01-2008, 10:58 PM   #2
Lil bastard's Avatar
If you'd rather be safe than sorry... go with Havoline or Texaco Dex Cool... I don't understand ... where's the problem ??
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 10-02-2008, 08:36 AM   #3
Dex Cool
My problem is finding the Havoline brand of Dex Cool, it doesn't seem as if the stores in my area carry it, but they all carry Prestone's version.
Also, if the Prestone Dex Cool formulation is indeed different, or has the ability to ruin my cooling system, it would probably be a good issue to clarify for other Boxster owners who may be in the same boat I'm in.
If I really wanted to err on the side of being safe, I would just buy the Porsche brand of coolant for $50 a jug (which is absurd). I was hoping someone on the board would have some extensive knowledge about what coolant brands would be compatible.
Old 10-02-2008, 08:56 AM   #4
http://www.renntech.org/forums/index.php?showtopic=4165&hl=audi
Old 07-21-2009, 04:37 PM   #5
ok, I know coolant flavours have been beaten to death on this and other forums. But I gotta ask yet another time.
I have been to every single auto parts store in my area. No one has any of the brands listed on Mike Focke's page or the various other threads.
I can find Prestone Dex Cool. I can not find Havoline or Texaco Dex Cool. Is Prestone Dex Cool the same? Any issue with using it if i do a through flush first?
My local Porsche dealer claims that the *only* time they use Porsche coolant is when they're refilling entire system under warranty work. Else they top it or fill it with generic Prestone. This comment has made me even more leery about taking the boxster in to them. I may have to drive to another dealer that's 2.5 hours away.
lizBox is offline   Reply With Quote
Old 07-21-2009, 06:51 PM   #6
I recently flushed and re-filled my coolant when I changed to the LN low temp thermostat. Purchased two gallons of "official" Porsche coolant from Pelican for $33 a piece; not worth risking anything else for pennies, IMO.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 07-22-2009, 07:02 AM   #7
Next time, try Sunset Porsche, recent purchases of coolant was in the $24/gal range...........
Old 07-22-2009, 07:06 AM   #8
If you could see the nightmares we have had to deal with that were caused by mixing the OEM coolant with aftermarket stuff (gelled lumps in the cooling system, plugged radiators, etc.), as well as the service bills they caused, you would view the use of the OEM coolant as cheap insurance…………
Old 07-22-2009, 05:36 PM   #9
Prestone web site...
They claim to be Porsche approved and when I called they claimed to be the OEM provider. Said Dex Cool is fine and all the same formulations.
In any event, I would just do the flush and refill procedure and not sweat it that much. The problems, as far as I can tell come from mixing different coolant types, having the wrong proportions, or not using distilled water.
urban_legend is offline   Reply With Quote
Old 07-23-2009, 06:22 AM   #10
And I can tell you, from a direct conversation with a Porsche zone rep, that Porsche “due to well know issues, does not approve, recommend or condone the use of any coolant other than their own.”
Basically, using any aftermarket coolant is a bit of gamble; you may be fine, or you may not. In the end, it is your car to do with as you please…………..
Old 07-23-2009, 07:49 AM   #11
A little clarification may be needed here.
The issue is mainly one of mixing the various types of coolant out there. It is here where compatibility problems pop up.
Porsche doesn't make anti-freeze, it's made by someone else. Nor is there any special proprietary voo-doo in their formula. It is basically phosphate and silicone free and the reason for this is that the phosphates attack the aluminum in the system and the silicone will mess up the oxygen sensors causing performance issues.
The chemistry is subtle though and that's where some of the incompatibilties happen, especially if you're mixing different fluids (formulations) even though they too may be phosphate/silicone free.
But, if you did a really thorough job of flushing the system, then most any phosphate/silicone free coolant would do the job. But, that could well be the rub.
In order to do such a thorough job, you'd likely have to drain, then fill with distilled water and run the car some miles to pick-up any errant coolant still in the system (obviously this would need to be in non-freezing conditions). In fact, you may need to repeat the process in order be certain all the old coolant was removed. Running for any length of time on pure distilled water would likely take a toll on the waterpump bearing as it uses the coolant as a lubricant between the impeller shaft and the bearing.
So while you could probably get away with it if you prepped the system as described above, it's probably better to simply go with the oem coolant - cheap insurance as someone put it.
But, many of you have used cars, and as such cannot be certain what the PO or PO's dealer may have used in the past. You may have gel forming in the system right now and not even know it. And, be aware that the coolant isn't really 'lifetime' - the 'best' coolants out there are currently 5yr./150k mi. (whichever comes first).
If I were to buy a used Boxster, one of the first things I'd do would be to flush the system and replace the fluid with oem coolant and distilled water, especially if the car were 5 yrs. or older.
One thing I'd like to see coming from Flat 6, LN Eng. or Pedro would be an in-line sleeve with a petcock that could be spliced into the lower radiator hose to make fluid changes easier for DIYers. It could be produced and sold cheaply and I suspect there's a market for it, maybe even rivalling oil filter adapters and mag plugs.
1976 BMW 2002
1990 BMW 325is
Old 07-23-2009, 08:05 AM   #12
Perhaps it is because we change out coolant on a fair number of cars, but I really do not see the OEM prescribed drain method as all that difficult. Once you have the belly pan section off (about 2-3 min.), everything is out in the open; the engine drain plug, the hoses to the radiators, the thermostat housing, and heater hoses. As for flushing the system, we fabricated some bits from hardware store sourced plastic fittings that allow us to attach a garden hose to either the engine or radiators and back flush the entire system with hot (135F) water. Typically, however, unless the system shows signs of problems, we usually do not flush the system, preferring to thoroughly drain it and then refill under vacuum with a 50/50 premixed OEM coolant and distilled water. Been doing it this way for a lot of years and to date have not had one come back with problems……
Old 07-23-2009, 08:20 AM   #13
All excellent points. But, you're not working on jackstands either...lol
1976 BMW 2002
1990 BMW 325is
Old 07-23-2009, 09:18 AM   #14
Actually, we have done this on jack stands from time to time, a few times at Porsche gatherings where an "impromptu" tech session was held. We did it to demonstrate for the onlookers how it can be DIY'd. Only real difference was how long it took to get the car up on the stands and being on your back rather than your feet.......still, not that bad of a “backyard” project.
Old 07-23-2009, 02:26 PM   #15
j/k... I have done it on stands and it's not that bad. Like many of the DIY tasks on the Boxster, the difficulty factor is often the product of actually getting to the work rather than the work itself.
But a handy, well placed petcock would make the job much easier, maybe even without having to raise the car at all.
1976 BMW 2002
1990 BMW 325is
Old 07-23-2009, 02:44 PM   #16
I believe that is what the marketing folks call “mystique”……….
Old 09-06-2009, 02:04 PM   #17
JFP - How do you fill the coolant under vacuum?
What tools do you use to refill under vacuum? Is there a DIY on that someplace?
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 09-06-2009, 02:10 PM   #18
Very simple, you use one of these and follow the directions; it is the same tool Porsche dealers use, only it comes with adaptors to fit any car and costs about 1/5 what Porsche sells them for................
Unit is made by Uview, and they have a great website.............
Old 09-06-2009, 08:24 PM   #19
Porsche "Purist"
Paul's Avatar
Great website? Where are the prices?
1987 924S. 2002 996TT. PST-2
Old 09-07-2009, 05:46 AM   #20
The sales site is on Amazon.com; unit costs about $100.....................
