Old 09-08-2008, 07:30 AM   #1
Send a message via Yahoo to TimAustinW
CEL - P1411 Secondary Air Injection System
I got a CEL this morning and my OBD is telling me it's a P1411 - the Bentley Manual gives two possible causes...
- Signal implausible/ implausible operating range / malfunction
- Short to Ground / below lower limit / lean mixture threshold
Can someone shed a little more light on this?
One thing to note, and I'm not sure if it means anything but this morning it was raining, the first time in several weeks. Also I just recently replace my MAF, not sure if that's related.
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
TimAustinW is offline   Reply With Quote
Old 09-08-2008, 11:27 AM   #2
Lil bastard's Avatar
The Motronic 7.2 DME Diagnostics manual lists a number of possible causes for P1411 - Secondary air injection system, bank 2.
  • A bad secondary air injection pump
    restricted air supply lines
    electronic changeover valve not functioning
    air changeover valve not functioning
    vacuum leaks
    wiring harness
    relay
    DME control module
It also calls for a testing procedure using the PIWIS or PST2 tester and calls for specific air temperature and air mass values.
I suspect that since it's isolated to Bank 2, it's probably vacuum leaks or the MAF, at least that's where I'd start. The other causes call for replacement of components and need the tester to isolate them.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 09-08-2008, 12:24 PM   #3
So that raises a question. I just had the MAF replaced in July. Later on when looking at the receipt they had my car listed as an S model which it is not. Is the MAF sensor different on an S than it is on the base Boxster? Could it be they installed the wrong MAF?
TimAustinW
