Old 08-01-2008, 03:01 PM   #1
Red alarm clip???
I saw something on ebay and it's a OEM Porsche alarm clip for convertible. Do anybody know what is it for and how it works?
spawn is offline   Reply With Quote
Old 08-01-2008, 03:10 PM   #2
Search young grasshopper and your journey shall be rewarded.
Jump
Silver 2002 S
http://homepage.mac.com/doug_schweig...ata/pcar-1.jpg
Jump is offline   Reply With Quote
Old 08-01-2008, 04:00 PM   #3
9eighty6's Avatar
Try "little red clip" & see the magic
1984 - 944 - The first one.
1984 - 928S - The loudest one.
2001 - Boxster - The best one.
9eighty6 is offline   Reply With Quote
Old 08-01-2008, 04:07 PM   #4
Old 08-02-2008, 09:47 AM   #5
Thanks for the photo. How does it work? Do you need any installation?
Old 08-02-2008, 10:12 AM   #6
the clip tells the car that the top is in locked mode and activates the interior motion detector so if you stick your hand inside the car with the clip on it trips the alarm.
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
Old 08-02-2008, 10:33 AM   #7
Thanks everybody.
Old 08-02-2008, 10:40 AM   #8
Quickurt's Avatar
Thanks everybody.
Do they have a 987 version, or does it work on both?
Great idea. I don't leave the top down unless I'm at a resturant where I can keep an eye out, but that doesn't mean I can watch it every second.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
Old 08-02-2008, 10:23 PM   #9
Red Clip
Some people spray paint them black so they are hard to see when installed. I'm thinking that if anyone knows what the red clip does they will be more apt to see red than black. Hence, I left mine red!
K Brandsma
98' Porsche Boxster
kbrandsma is offline   Reply With Quote
Old 08-03-2008, 07:55 AM   #10
Works like a champ...
Old 08-03-2008, 06:35 PM   #11
Just snapped mine in place today.
I could not leave my car with the top down without it.
Old 08-03-2008, 06:54 PM   #12
Jaxonalden's Avatar
OK, I have a question. I have one also and have yet to use it. With it in place, the interior ultra-sound motion detector is enabled with the top down. The clip also disables the top from raising.
My question is; If the alarm is set and someone knows what the red clip is and they reach over and remove it, will the alarm go off? I know the detectors are under the latch assembly pointing down.
Old 08-03-2008, 07:24 PM   #13
Lil bastard's Avatar
The answer is no, the alarm will not go off, unless the person accidenntally moves within the area of the sensors. The red clip isn't intended for the alarm, it's design purpose is to disable the top from operating when you use the speedster hump and tonneau cover options.
The alarm system was never intended to operate with the top open, it used the same micro-switch in the windshield header to determine that the top was closed. The red clip only tricks it into thinking the top is closed, nothing more.
The infrared motion sensors are not that sensitive, and even with the red clip in place, it's possible to slowly move your arm inside and remove something, plus, it's coverage area isn't complete, there are several blind spots. So you really should never leave any valuables inside.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 08-04-2008, 05:36 AM   #14
LB's right on... lots of unarmed dead spots.
Reaching into your center cubby holes or your dash to snag your GPS or radar detector will trigger the alarm.
However, anything in the door pockets or rear storage compartment (above the engine) is unprotected. Same goes with your center windscreen or the rollbar inserts. All are at greater risk for theft when the top is left down and the clip is in use.
Center console is wired to the system, so if it's opened the alarm will sound regardless of red clip use.
Raising your windows with our without the red clip's use is a good idea for top down parking if you must do it.
The red clip, BTW, was designed for owners of factory humps. The idea was to disable the top switch so one could not accidently to raise the top when the humps were installed. Factory humps came with the red clip and extras were sold through the parts department because they're easily misplaced.
Old 08-04-2008, 08:54 AM   #15
9eighty6's Avatar
As ineffective as it might be, I would consider it to be better than no red clip if you do decide to park with the top down.
Old 08-04-2008, 12:16 PM   #16
Quickurt's Avatar
Parking with the top down is only suggested if you can keep the car in site and carry a large calibre pistol.....
Old 08-04-2008, 12:32 PM   #17
If you're a good shot, a .380 will do fine. Also, using a smaller caliber weapon will do less damage to your car if you're not a good shot.
I do agree with the whole line of thinking though. In principle, you're spot on!
After some fine upstanding citizen spat out his gum onto my brand new floor mat when the top was down one day when I ran into a grocery store, I no longer leave the top down anywhere out of my line of sight.
Old 08-04-2008, 05:06 PM   #18
Quickurt's Avatar
I do believe official factory procedure for the above infraction would be 8mm Lugar, multiple shots.
Old 08-04-2008, 06:19 PM   #19
Jaxonalden's Avatar
RandallNeighbour & Quickurt,
The next time some prick spits their gum onto your new floor mat try this; peanut butter It gets 'em every time.
Old 08-04-2008, 09:29 PM   #20
Question Do they have a 987 version, or does it work on both?
BigOne
Basalt Black Metallic / Black Top Special Colour, Silver Grey Leather, Instrument Dials Black 997, Tiptronic S, Heated Seats, 19" Carrera S Rims, Multi Function Steering Wheel with PCM, Crested Wheel Caps, Cruise Control, PASM 987, Alarm + Remote (433 MHz), Wind Deflector + Storage, Auto Climate Control, Sports Chrono Package Plus, ‘BOSE’ Sound System, CD Changer CDC-4, Self Dimming Mirror + Rain Sensor, Power Seats + Driver Memory, PCM 2, Bi-Xenon with Headlamp Cleaning.
manguasha is offline   Reply With Quote
