Old 07-30-2008, 06:30 PM   #1
Relocating A/C unit to center console
I'm interested in relocating the a/c display to the center console area (behind the power window switches, in place of the ash tray, and blank rear vents). I can dremel the area out, but any idea how hard it would be to extend the wires?
I will be putting the Avic D3 in place of the factory radio, and will need both spaces. Unfortunately, I also like the extra space added by GT3 center console delete kit. Any ideas?
brent95m3 is offline   Reply With Quote
Old 07-30-2008, 08:35 PM   #2
don't actually know how deep the climate control unit is, but the console isn't very deep (maybe 5 inches). You may not have the space for it, and it may be kinda awkward.... i dunno if you can have your cake and eat it too
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
Old 07-30-2008, 08:38 PM   #3
I would suggest putting it in the lower space, and not doing the GT3 delete. I do not think you can make it fit where the ashtray is, due to depth, not to mention the fact that you'd have to create a whole new harness to extend the wiring to it. Seems more PITA than the benefits are worth.
Patrick
Old 07-31-2008, 05:39 AM   #4
Where the ash tray is??? How do you think it could possibly fit in that small of space?
Old 07-31-2008, 08:48 AM   #5
Heh, no. I would remove (using a dremel) the rear dummy window switches. It will fit in length and width, if I remove these, but as others have pointed out, probably not enough depth. I will take a look at it when I pull everything out for the install, but I think I will have to put the center console back in.
Old 07-31-2008, 05:04 PM   #6
I've had my entire console pulled apart whilst moving components around from top to bottom. I also replaced the ash tray with the non-smokers tray. It would be a far fetch to fit the a/c unit in there precisely because of the depth issue.
Old 07-31-2008, 05:43 PM   #7
I agree that I dont think the depth would work. The wiring would be a nightmare and you would essentially be butchering up a Porsche. Reloacating the units and adding a D3 is relatively easy and is reversible but trying to throw the climate contorls to the center console area would just look weird (in my opinion).
97 Arctic Silver/Boxster Red
Carbon Everything
De-ambered
De-snorkled
Litronics
Eibach Pro Kit
Dansk Sport exhaust
Cheap Chinese headers
Silver console and bumperettes
AVIC D3
15mm H&R spacers in the rear
SSR GT3 19's
GT3 Carbon Replicas
Alcantera door panels
JL Aduio 5 channel powering Polks and Clif Designs
To do/complete:
Elemental Designs 10" subs in fiberglass enclosures behind seats
Carbon 3 spoke install with custom stereo control buttons (tiptronic wheel)
angman is offline   Reply With Quote
