Old 07-21-2008, 12:08 PM   #1
Silver handle below door handle
Hi I have a 2001 Yellow S and the silver bar below the door handle is kinda scratchy so I was wondering if anyone knows where to buy these? Also the clib below the Silver Bar is missing exposing the screw, I'm sure this has happened to a few of you guys..?
BoxsterLewis is offline   Reply With Quote
Old 07-21-2008, 05:57 PM   #2
I don't really know what your talking about, but I don't know the parts to my door handle that well so, thats probably why (a pic may help).
However, this may help you:
http://dcauto.gotdns.com/illustration/index/509261621
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
Old 07-22-2008, 08:30 AM   #3
Thanks for the image frag dude but its actually the silver bar that the plastic cover that covers the mini cubby hole sits on top of? Does that help? Right above the silver part theres a clip that covers a screw that I'm missing on both doors.
Old 07-22-2008, 09:35 AM   #4
Ok, I think I got it. Is it part 29 in this diagram?
http://dcauto.gotdns.com/illustration/index/475724103
-H7 HID Upgrade
Old 07-22-2008, 09:40 AM   #5
I presume it's the inside you are talking about... If so, this is the diagram you are looking for:
http://dcauto.gotdns.com/illustration/index/475724103?class=illo_title
Clips are part #29.
p/n you need are:
986.555.722.01 plus the color code you need
You could just order the black ones (.01C) and paint yourself. Bet you could do as good of a job (or at least 95% as good) and offset the 5% by pocketing $71 difference (less $5-10 for paint).
The grab bar, which I think is what you are also asking about is part #26 in the diagram.
Old 07-22-2008, 10:25 AM   #6
BINGO you rock, the ones i was talking about are 29 and 26, do you guys have black ones? I have silver and 26 is all scratched up...
Wow 26 is close to $500???
Old 07-22-2008, 11:17 AM   #7
I've got a pair of #29 in original unpainted black, and a pair of #29 in Arctic Silver... PM me if you need it...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 07-23-2008, 07:27 AM   #8
No need to replace the pull bar...it can be removed and repainted for pennies compared to replacing. Color is Aluma Look "ALU 03 EFFECT " and is listed for trim etc.
Code is 4W9 and Dupont stock code is X1070.
The key is to not wear any rings on your fingers; they do too much damage.
Old 07-23-2008, 07:40 AM   #9
Can I get that at a local autozone or something? If you scratch it its black underneath so theres a pretty thick coat of silver on it.
Old 07-23-2008, 10:15 AM   #10
Send a message via Yahoo to TimAustinW
If you want black why not by some upholstery leather and some 3M spray adhesive. I wrapped mine with leather and they turned out pretty well.
You can see it in the DIY I did...
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
TimAustinW is offline   Reply With Quote
Old 07-24-2008, 03:08 PM   #11
The leather looks nice. The bar is painted silver, then clear coated. I would sand the damaged area smooth and sand enough of the rest of the bar so the new paint can grip. Clear coat and buff when finished. Keep the rings in the drawer.
