Old 06-07-2008, 08:22 AM   #2
KevinH1990's Avatar
I had the P0446 code. Replacing the purge valve and the charcoal canister in the fuel system eventually solved the problem.
The other two codes are:
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold
P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold
Since they've replaced the MAF, it's possible you need to replace the two O2 sensors before the catalytic converters. I'm not an expert on this though.
I'm wondering why your dealer can't figure this out.
