Old 04-09-2008, 10:55 AM   #1
Send a message via Yahoo to bermuditis
Unhappy How do you know when your clutch is going?
I have a 2000 2.7 boxster that I just changed the maf on. Part number 996606124/0280218009 was changed with the same numbered part. Now when I shift gears the car revs to 3000 rpm then comes back down and seems to catch and accelerate quickly. If I ease off and try to be gentle with it, it still seems to have the over rev. The car runs hotter now too. I don't remember it doing that before the maf change. It may have, I'm just not sure. Are these symptoms of the clutch going or is it a maf problem? Idles great now and all else seems ok.
bermuditis is offline   Reply With Quote
Old 04-09-2008, 11:24 AM   #2
I'd call another dealer and ask for the newest partnumber for that part for your MY. Usually it takes more than afew miles for the engine to adjust and recalibrate so if it isnt working after... say 100 miles, then take it back and get a new one.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 04-09-2008, 11:31 AM   #3
Originally Posted by bermuditis
Are these symptoms of the clutch going...?
Nope. Clutch wear is gradual. You may notice the clutch pedal is increasingly closer to the floor to engage. When changning gears and accelerating, the clutch "slips"(engine revs/nothing happens) befoe engaging.
Sounds like something got hosed up when you did your replacement.
2000 Boxster S
http://img.photobucket.com/albums/v2...terSAvatar.jpg
"It is better to enter a corner slow, and come out fast, than to enter a corner fast, and come out dead." - Sir Stirling Moss
J-RAD is offline   Reply With Quote
Old 04-09-2008, 11:49 AM   #4
Yes CJ is on the right track. But you need to take his answer a step further.
I read that when you change your MAF you need to disconnect the battery for about 10 minutes to clear the ECU. Then the ECU will re-learn the new MAF settings, values, calibration... and run correctly. Otherwise the old MAF values are locked in the ECU.
*Have your radio code ready since when you disco the battery it will think it was stolen.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
Old 04-10-2008, 12:00 AM   #5
BTW.
for your car
986 606 125 01 should be about $300 (w/ E-accelerator)
996 606 123 00 should be about $250 (w/o E-accelerator)
996 606 124 00 is for a boxster S not sure what the other PN you mentioned is for.
but yeah, when you get the right one...
i'd unplug the battery, then go watch some tv, like a sitcom, then come back, plug it in. then drive it for 1/2 a tank.
http://b-ng.com/audi/images/avatar.jpg
Benny
lubrify.com
Benny986 is offline   Reply With Quote
Old 04-10-2008, 08:21 AM   #6
Brucelee's Avatar
I would go with this explanation.
Rich Belloff
