Old 03-22-2008, 05:45 AM   #1
Talking Is there really a 6th gear on my S?
LOL.
I have never shifted into 6 on my S, just might need to do it one day to make sure that is it really there.....What is the shift speed for 6th gear? I know I have been up to at least 125 in 5th....
Anyone else have these type of thoughts?
meerzee is offline   Reply With Quote
Old 03-22-2008, 06:17 AM   #2
I've only got a five speed, but I hear the same thing from others with 6 speeds ... great for 140+ mph driving, but rarely used any other time and a bit of a waste. Mostly there to differentiate the S from the non-S.
I wonder how much low end grunt your car might have with a 5 speed on it with lower gear ratios
Should I upgrade to a 3.4, I'm going to attempt to keep a 5 speed tranny in my car.
Old 03-22-2008, 07:25 AM   #3
Why in the world would you NOT do that upgrade? I'm thinking about that very same task... I wonder if the boys at RUF would do such a conversion for a non S.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 03-22-2008, 07:29 AM   #4
bmussatti
Posts: n/a
I use 6th gear all the time. On every drive. Meerzee, what do you use when cruising on the highway?
Old 03-22-2008, 07:33 AM   #5
5th gear.....falls back nicely for all 70-85 driving right around 3k RPM.
heck 125 is about as high I as I can take it anywhere around here.
Unless Max or Gary know of any secret hot spots....
Inquiring minds -need- to know.
Old 03-22-2008, 07:42 AM   #6
Lol why not just put it in 6th? less stress on the engine.
06 Cayman S
07 RR HSE
Blkboxster is offline   Reply With Quote
Old 03-22-2008, 08:04 AM   #7
Brucelee's Avatar
I used to use 6th all the time in the S.
Runs quieter, improves MPG, extends engine life.
With the crap stereo that I had, I couldn't hear the music unless I used 6th.
Rich Belloff
Old 03-23-2008, 06:13 PM   #8
I use 6th gear all the time. 60+ mph and not racing and it 's virtually all the time.....
Waste neither time nor money but use both for your own and your neighbors good.
merplastic is offline   Reply With Quote
Old 03-23-2008, 06:32 PM   #9
Talking
I shift to 6th after a quick squirt to 80 in 3rd, on entrance ramps. When I shift to 4th i'm always tempted to run 100+, bad for insurance premiums!!
986chris is offline   Reply With Quote
Old 03-23-2008, 06:48 PM   #10
I do the same thing,that's too funny.
Does going from 3rd-6th have any bad effect on the tranny?
Old 03-23-2008, 07:27 PM   #11
imho i think you use the tranny less, hey clutch too. gotta be better.
Old 03-23-2008, 07:46 PM   #12
Send a message via AIM to PSL-Boxster
i dont have the 6th gear on my box, but i do have the tiptronic option... whenever its just in drive it almost immediately shifts into 5th gear at 40 ish mph for fuel economy.. i guss that the 6th gear prolly really helps well on that topic considering gas prices these days
PSL-Boxster is offline   Reply With Quote
Old 03-23-2008, 07:57 PM   #13
HB.
Yes!
I'd rather wear out my clutch then wear out the tranny. It's the same with down shifting.
HB. is offline   Reply With Quote
Old 03-24-2008, 05:48 AM   #14
meerzee, I'm with you I barely use it. Most of the time I am driving locally and if I'm on a highway it is for a short period of time, so no 6th. When drove up to Duluth last Fall I used it, but otherwise very rarely.
05 987 S SOLD
Arctic Silver
Bose/Xenon
05 Touareg V8
Black
drburton is offline   Reply With Quote
Old 03-24-2008, 08:17 PM   #15
So my question here is why is it bad to shift from 4th to 6th? I doubt I am putting more stress on the engine/tranny by skipping 5th
But please educate me here
cristopher
*youth is wasted on the young*
Photos of my Boxster S
Painted center console, artic silver
, De Snorkle, 18" Carrera lightweight - 285-30-18 - Fabspeed Exhaust
http://www.cristopherbenitah.com/boxster.jpg
cbenitah is offline   Reply With Quote
Old 03-24-2008, 08:45 PM   #16
Why is it bad to skip gears?
Old 03-25-2008, 01:30 AM   #17
The racers on this forum will correct me if I am wrong.
I was under the impression that you should try to avoid skipping gears when you are downshifting for corners. If you watch vids of pro racers taking corners, they heel-toe down from 4th to 3rd and then again heel-toe down into 2nd gear for the final turn. By sequentially downshifting you (theoretically) have less chance of over-reving the engine and less wear and tear on the transmission.
Soo.... I really have not heard that skipping a gear while upshifting will hurt the clutch or the transmission. If so, that is a new one on me.
And miles to go before I sleep
2004 986S Silver Anniversary
hjkim550 is offline   Reply With Quote
Old 03-25-2008, 03:40 AM   #18
downshifting at the track with a throttle blip helps shorten the time it takes the engine to recover from the lower ratio you're about to engage. And if we all remember a few years back the Corvette had a 3rd 4th gear block out that would engage un less you had your boots in it.
Old 03-25-2008, 05:33 AM   #19
Believe it or not, the Vettes still have the skip-shift, which helps them with the EPA/MPG. I hated it in the last one I had albeit it only came into play when in traffic - otherwise I just stepped on it and it did not activate.
Bob Z. is offline   Reply With Quote
Old 03-25-2008, 08:26 AM   #20
Brucelee's Avatar
I normal driving, I can see no issue with skipping gears, did it all the time in the S.
The issue is always to match the gear and engine speed to the speed of the car.
I think?
Rich Belloff
